12-05-2003 05:06 AM - edited 03-02-2019 12:10 PM
My archive status shows some number of failed devices with the above message. All information for the devices is correct and when I manually telnet to the devices it takes some time for the banner to display and then the prompt to set itself. Is there a way to have the archive process wait for some amount of time prior to sending credentials?
Thanks in advance
pat
12-05-2003 01:09 PM
What type of devices are returning this error? Using RME to archive 4506 & 4507 with port security enabled have a known bug.
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCec59408
12-08-2003 04:28 AM
actually it is mostly 1600 and 1700 routers with tacacs
thanks for the feedback
pat
