Community Member
archiving running config using RME
Is there a way to archive running config on the Cat 5500 switches using RME 3.4 (W2K)?
Thanks.
_ Alex
1 REPLY
Community Member
Re: archiving running config using RME
The Catalyst 5500 doesn't have a running config but if you wanna mean the configuration of the Catalyst 5500 you must find out at cisco.com if your CatOS is supported by the RME 3.4. I hope it helps you.
83
