Bronze
Are L-3 switches supports routing protocols?
Dear all,
Are L-3 switches can able to run routing protocols?
Thanks in advance..
Regards..
Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
Re: Are L-3 switches supports routing protocols?
yes they can run routing protocols
after all they are acting as routers too
guy
GW6
It would be helpful to know what model you are talking about. If you're discussing the 3550 line then you will most likely need the EMI IOS versions for this functionality.
91
