Community Member
ARP issue
I have assigned same ip address to two ethernet interfaces of cisco 7200 router using the backup interface command.One is active and other is Standby.When Active goes down,Standby link does not come up automatically.am facing a problem with ARP. when i delete the ARP in PC am able to ping the router.
Can anyone help me out to solve this problem.
tselvan
Re: ARP issue
A router never allows two of its own interfaces to have the same ip address (or the same subnet) unless, one of the interfaces is down. (in your case, due to backup command, one of the interfaces was in standby mode, and thats why it first of all took the ip address. This setup should be avoided.
Re: ARP issue
As Shanky states: This setup should be avoided. Try to implement HSRP. That is the preferred solution for interface-redundancy.
Community Member
Re: ARP issue
Set the MAC Address manually on backup interface to be same as Active interface.
Community Member
Re: ARP issue
We use a BVI interface with 'bridge 1 protocol ieee' and 'bridge 1 route ip' on the interface. That gives us 2 connections to the router with the one IP address.
Community Member
Re: ARP issue
Hi Peter
Can you be kind enough to give me the config that you've mentioned here? I'm interested in configuring my spare interface on the 3660 to provide back up in case the primary ineterface goes down. Thanks in advance. If possible please emial to vincentn@mediamonitors.com.au
175
