Community Member
ARP issues - Trunked 3620 - 2950
I have a bit of an issue in that I can't get dot1q trunking going between a 3620 and a 2950.
Equipment: 3620 - 10mbps ETHERNET connected to a 2950 - 100mbps FE.
Interface config on 3620.
interface Ethernet1/0
description #### Trunk link to Syktower2950 ####
no ip address
no ip redirects
no ip route-cache
no ip mroute-cache
load-interval 30
half-duplex
no cdp enable
interface Ethernet1/0.1
description #### Native VLAN1 ####
encapsulation dot1Q 1 native
ip address 10.5.5.1 255.255.255.0
no ip redirects
no ip route-cache
no ip mroute-cache
no cdp enable
Ports all seem to be up fine.
If I put an IP address on Ethernet 1/0, can access the 2950 VLAN1 no probs.
When I put the IP address on a subinterface, I start getting ARP error messages.
01:23:09: IP ARP: creating incomplete entry for IP address: 10.5.5.2 interface E
thernet1/0.1
01:23:09: IP ARP: sent req src 10.5.5.1 00d0.bad9.c511,
dst 10.5.5.2 0000.0000.0000 Ethernet1/0.1
01:23:09: IP ARP rep filtered src 10.5.5.2 000f.3425.5b40, dst 10.5.5.1 00d0.bad
9.c511 wrong cable, interface Ethernet1/0
I'm pretty sure it isn't a cable problem because when the IP address is on the interface all goes well. When on the sub-interface it fails.
For some reason, the 3620 is filtering the ARP response.
Any ideas?
Steven Schmidt.
1 REPLY
Re: ARP issues - Trunked 3620 - 2950
I'd try to check:
1) duplex
There is half-duplex on the router side. Is it also on the switch side?
2) switch trunk config
Don't forget 2950 is desirable by default on 802.1q trunk ports.
Use switch(config-if)#switchport nonegotiate
while connecting to a router.
3) proper IOS on the router.
802.1q requires IP Plus Feature Set generally.
I rmemeber some older IOS versions had problems with native VLAN configuration (encapsulation ... native option was missing).
The workaround was similar to your config - not configuring native VLAN subinterface, using native VLAN IP address on the interface.
Milan
197
