Webcast-Catalyst9k
AS-5300 low memory
Hi team:
In these weeks i had some problem with diferents AS-5300, all AS are runing de same IOS, and has the same kind of service ( Internet Access )
All AS had runing 6 months without any problem.
The AS. stop to response the Telnet, ping, or SNMP. When you try to conect by console the AS show this mesagge.
"low on memory, try again later"
All access-servers have the maximum memory.
Anybody knows why is the reason of this trouble ?
thanks
Pablo Sánchez.
Bronze
Re: AS-5300 low memory
It sounds like you have a memory leak. I would suggest the following:
- ensure that you have recent code to avoid any known problems.
- otherwise, open a case with the TAC.
- See this link for some info on what data to collect and analyze:
http://www.cisco.com/warp/public/63/mallocfail.shtml#subfour
Same problem here, running 12.2(2)XB6 and MICA 2.9.2.0 code... 64/16MB memory. Runs about a month and then services start to fail, "sh run" displays nothing etc.
106
