AS 5800 problem
Hi all,
I had only 2 bad modems in the access and i want to shut then down but the problem that i cant do that because i didnt found any supportive command for that.
the IOS version is 12.2.6 and the modem shut command is disabled, the only command i know is to shut down all the spe which meaning shit down 12 modems instead of only, did any one had a solution for that
regards,
Silver
Re: AS 5800 problem
Can do the following, suppose we want to busyout / shut port 1/03/04 & 05
c5800#conf t
Enter configuration commands, one per line. End with CNTL/Z.
c5800(config)#port 1/03/04 1/03/05
c5800(config-port)#shut
c5800#sh spe
Summary :
Ports : Total 504 In-use 0 Free 4 Disabled 500
Calls : Modem 0 Digital 0 Voice 0 Fax-relay 0
SPE SPE SPE SPE Port Call
SPE# Port # State Busyout Shut Crash State Type
1/03/00 0000-0005 ACTIVE 0 0 0 ____ss ______
Thanks, Mak.
Re: AS 5800 problem
Thanx a lot
It helps me
regards,
84
