AS2509 problem
Thanks for any help in advanced.
I have an AS2509 installed which act as a terminal/comm server. the async port of the AS2509 was connected to the aux port on routers and console port on switches.
I got a problem in which, the connection of the router was always on, and it can not be cleared even though i use "clear line x" what is the possible problem?
here is the sh run:
version 12.1
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname AS2509_KLJ
enable secret 5 xxxxx
enable password 7 xxxxx
username admin password 7 xxxxx
ip subnet-zero
no ip domain-lookup
ip host 6509main 2001 10.0.0.1
ip host as1 2006 10.0.0.1
ip host as2 2007 10.0.0.1
ip host 6509standby 2008 10.0.0.1
interface Loopback0
ip address 10.0.0.1 255.255.255.0
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
no fair-queue
interface Async9
no ip address
no peer default ip address
ip classless
ip http server
line con 0
line 1 8
session-timeout 2
exec-timeout 0 30
transport input telnet
transport output none
line aux 0
password 7 xxxxx
login local
modem InOut
transport input all
speed 38400
flowcontrol hardware
line vty 0 4
password 7 xxxxx
login
transport preferred telnet
transport input pad v120 telnet rlogin udptn
end
here is the sh line:
AS2509_KLJ#sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - - - - - 6 0 0/0 -
1 TTY 9600/9600 - - - - - 5 204 0/0 -
* 2 TTY 9600/9600 - - - - - 2 0 0/0 -
3 TTY 9600/9600 - - - - - 1 0 0/0 -
4 TTY 9600/9600 - - - - - 1 0 0/0 -
5 TTY 9600/9600 - - - - - 1 0 0/0 -
6 TTY 9600/9600 - - - - - 3 0 0/0 -
* 7 TTY 9600/9600 - - - - - 2 2809 10210/30440 -
8 TTY 9600/9600 - - - - - 2 0 0/0 -
* 9 AUX 38400/38400 - inout - - - 12 0 6/0 -
10 VTY - - - - - 2 0 0/0 -
11 VTY - - - - - 1 0 0/0 -
12 VTY - - - - - 1 0 0/0 -
13 VTY - - - - - 0 0 0/0 -
14 VTY - - - - - 0 0 0/0 -
  • Other Network Infrastructure Subjects
1 REPLY
Re: AS2509 problem
Configure "no exec" on line 1 8 and also on line aux if this one is used to reverse telnet to another async device.
Cheers
120
