AS5200 Dialup Connection
I am configuring an AS5200 Router to accept 2 T1 lines. One going to Controller T1 0 and the other going to Controller T1 1. Each T1 has its own telephone number. I have 24 56k modems. I want Controller 0 to have access to modems 1-3 and Controller 1 to have access to modems 4-24.
Currently I have one T1 line connected to Controller T1 0 that has access to all 24 modems. Is it possible to divide the modems by having a separate T1 going to each controller? Thanks! I have attached a config listingCurrent configuration:
version 11.3
service timestamps debug uptime
service timestamps log uptime
hostname AS5200
aaa new-model
aaa authentication login console none
aaa authentication ppp XXXXXX XXXXXX
aaa accounting network default start-stop radius
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXX.
enable password XXXX
username XXX password 0 XXX
controller T1 0
clock source line primary
cas-group 0 timeslots 1-24 type fxs-loop-start
controller T1 1
clock source line secondary
interface Loopback0
no ip address
ipx network xxxxxxxxx
interface Ethernet0
ip address x.x.x.x x.x.x.x
ipx encapsulation SAP
ipx network xxxxx
no mop enabled
interface Serial0
no ip address
no ip mroute-cache
shutdown
interface Serial1
no ip address
shutdown
interface Group-Async1
ip unnumbered Ethernet0
encapsulation ppp
ip tcp header-compression passive
async mode interactive
ipx ppp-client Loopback0
peer default ip address pool setup_pool
ppp authentication pap westminster
group-range 1 24
interface Dialer1
no ip address
no cdp enable
ip local pool setup_pool x.x.x.102 x.x.x.125
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.x
no logging buffered
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
radius-server host x.x.x.x auth-port xxx acct-port xxx
radius-server key xxxx
line con 0
exec-timeout 0 0
logging synchronous
login authentication console
line 1 24
autoselect during-login
autoselect ppp
modem Dialin
line aux 0
no exec
password XXXX
modem InOut
transport input telnet
line vty 0 4
password XXXX
scheduler interval 1000
end
1 REPLY
Re: AS5200 Dialup Connection
Often times complex configuration issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
94
