AS5248 Radius problems
I have a AS5248 configured like the following:
AS5248#sh run
Building configuration...
Current configuration:
version 11.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname AS5248
aaa new-model
aaa authentication login default radius local
aaa authentication login no_radius enable
aaa authentication ppp default if-needed radius
aaa authorization network default radius
aaa accounting exec default start-stop radius
aaa accounting network default start-stop radius
enable password 7 VVVVVVVVVVVVVV
username admin password 7 ZZZZZZZZZZZZZZ
username telenorth password 7 EEEEEEEEEEEEEE
ip subnet-zero
no ip finger
ip radius source-interface Ethernet0
isdn switch-type primary-ni
controller T1 0
clock source line primary
cas-group 0 timeslots 17-24 type e&m-fgb mf dnis
controller T1 1
shutdown
clock source line secondary
interface Ethernet0
ip address XX.XX.XX.XX 255.255.255.224
interface Serial0
no ip address
no ip mroute-cache
shutdown
interface Serial1
no ip address
shutdown
interface Group-Async1
ip unnumbered Ethernet0
no ip directed-broadcast
encapsulation ppp
async mode interactive
peer default ip address pool ASYNC
ppp authentication chap
group-range 1 12
ip local pool ASYNC XX.XX.XX.XX XX.XX.XX.XX
ip classless
ip route 0.0.0.0 0.0.0.0 xx.xx.xx.xx
radius-server host xx.xx.xx.xx auth-port 1645 acct-port 1646
radius-server key northern
line con 0
password 7 XXXXXXXXXXXX
line 1 4
password 7 XXXXXXXXXXXXX
autoselect during-login
autoselect ppp
modem InOut
transport input all
line 5 12
autoselect ppp
modem InOut
transport input all
line 13 48
line aux 0
line vty 0 4
end
Authentication always fails on dial in...here is the debugs....
Neither Dialin nor telnet will work...
5d02h: TTY50: EXEC creation
5d02h: AAA/AUTHEN: create_user (0x1BB198) user='' ruser='' port='tty50' rem_addr='65.125.219.144' authen_type=ASCII service=LOGIN priv=1
5d02h: AAA/AUTHEN/START (1741254016): port='tty50' list='' action=LOGIN service=LOGIN
5d02h: AAA/AUTHEN/START (1741254016): using "default" list
5d02h: AAA/AUTHEN/START (1741254016): Method=RADIUS
5d02h: AAA/AUTHEN (1741254016): status = GETUSER
5d02h: AAA/AUTHEN/CONT (1741254016): continue_login (user='(undef)')
5d02h: AAA/AUTHEN (1741254016): Method=RADIUS
5d02h: AAA/AUTHEN (1741254016): status = GETPASS
5d02h: AAA/AUTHEN/CONT (1741254016): continue_login (user='test')
5d02h: RADIUS: ustruct sharecount=1
5d02h: RADIUS: Initial Transmit id 19 65.125.219.133:1645, Access-Request, len 78
5d02h: Attribute 4 6 417DDB9E
5d02h: Attribute 5 6 00000032
5d02h: Attribute 61 6 00000005
5d02h: Attribute 1 6 74657374
5d02h: Attribute 31 16 36352E31
5d02h: Attribute 2 18 82D0CA83
5d02h: RADIUS: Received from id 19 65.125.219.133:1645, Access-Reject, len 36
5d02h: Attribute 18 16 52657175
5d02h: AAA/AUTHEN (1741254016): status = FAIL
5d02h: AAA/AUTHEN/ABORT: (1741254016) because .
5d02h: AAA/AUTHEN: free_user (0x1BB198) user='test' ruser='' port='tty50' rem_addr='65.125.219.144' authen_type=ASCII service=LOGIN priv=1
5d02h: AAA/AUTHEN/START (3786985331): port='tty50' list='' action=LOGIN service=LOGIN
5d02h: AAA/AUTHEN/START (3786985331): using "default" list
5d02h: AAA/AUTHEN/START (3786985331): Method=RADIUS
5d02h: AAA/AUTHEN (3786985331): status = GETUSER
5d02h: Call mgmt per minute statistics:
active list length: 0
history list length: 0
0 timeslots active at slot 0, ctrlr 0
0 timeslots active at slot 0, ctrlr 1
5d02h: AAA/AUTHEN/ABORT: (3786985331) because Login timed out.
5d02h: AAA/AUTHEN: free_user (0x1BB198) user='' ruser='' port='tty50' rem_addr='65.125.219.144' authen_type=ASCII service=LOGIN priv=1
5d02h: AAA/AUTHEN/START (4055039711): port='tty50' list='' action=LOGIN service=LOGIN
5d02h: AAA/AUTHEN/START (4055039711): using "default" list
5d02h: AAA/AUTHEN/START (4055039711): Method=RADIUS
5d02h: AAA/AUTHEN (4055039711): status = GETUSER
5d02h: AAA/AUTHEN/ABORT: (4055039711) because Login timed out.
5d02h: TTY50: Line reset by "Virtual Exec"
5d02h: TTY50: Modem: READY->READY
5d02h: VDEV_ALLOCATE: slot 1 and port 5 is allocated.
5d02h: CSM_RX_CAS_EVENT_FROM_NEAT:(001D): EVENT_CALL_DIAL_IN at slot 1 and port 5
5d02h: CSM_PROC_IDLE: CSM_EVENT_DSX0_CALL at slot 1, port 5
5d02h: Mica Modem(1/5): Configure(0x0)
5d02h: Mica Modem(1/5): Configure(0x1)
5d02h: Mica Modem(1/5): Call Setup
5d02h: TDM(reg: 0x213A100): two way connection requested.
5d02h: TDM(reg: 0x2138100): Close connection to STo6, channel 18
5d02h: TDM(reg: 0x2138100): Close connection to STo4, channel 18
5d02h: TDM(reg: 0x2138100): Connect STi6, channel 18 to STo0, channel 5
5d02h: TDM(reg: 0x2138100): Connect STi0, channel 5 to STo6, channel 18
5d02h: Mica Modem(1/5): State Transition to Call Setup
5d02h: Mica Modem(1/5): Went offhook
5d02h: CSM_PROC_IC1_RING: CSM_EVENT_MODEM_OFFHOOK at slot 1, port 5
5d02h: Mica Modem(1/5): Rcvd Digit detected(#)
5d02h: Mica Modem(1/5): Rcvd Digit detected(4)
5d02h: Mica Modem(1/5): Rcvd Digit detected(8)
5d02h: Mica Modem(1/5): Rcvd Digit detected(9)
5d02h: Mica Modem(1/5): Rcvd Digit detected(*)
5d02h: CSM_PROC_IC2_COLLECT_ADDR_INFO: CSM_EVENT_ADDR_INFO_COLLECTED (DNIS=4889898, ANI=) at slot 1, port 5
5d02h: CSM_RX_CAS_EVENT_FROM_NEAT:(001D): EVENT_CHANNEL_CONNECTED at slot 1 and port 5
5d02h: CSM_PROC_IC4_WAIT_FOR_CARRIER: CSM_EVENT_DSX0_CONNECTED at slot 1, port 5
5d02h: Mica Modem(1/5): Link Initiate
5d02h: In actv_c_proc_message,
access type CPM_INSERT_NEW_CALL,
call type CPM_CT1_ANALOG:
CSM completed connecting a new modem call
5d02h: Mica Modem(1/5): Rcvd Digit detected(0)
5d02h: Mica Modem(1/5): Rcvd Digit detected(6)
5d02h: Mica Modem(1/5): State Transition to Connect
5d02h: Mica Modem(1/5): State Transition to Link
5d02h: Mica Modem(1/5): State Transition to Trainup
5d02h: Mica Modem(1/5): State Transition to EC Negotiating
5d02h: Mica Modem(1/5): State Transition to Steady State
5d02h: TTY6: DSR came up
5d02h: tty6: Modem: IDLE->READY
Added a new CT1 analog call to the active-calls list
CC-Slot#0, DSX1-Ctrlr#0, DS0-Timeslot#19
Mdm-Slot#1, Mdm-Port#5, TTY#6
5d02h: TTY6: EXEC creation
5d02h: AAA/AUTHEN: create_user (0x1632D4) user='' ruser='' port='tty6' rem_addr='async/4889898' authen_type=ASCII service=LOGIN priv=1
5d02h: AAA/AUTHEN/START (439257908): port='tty6' list='' action=LOGIN service=LOGIN
5d02h: AAA/AUTHEN/START (439257908): using "default" list
5d02h: AAA/AUTHEN/START (439257908): Method=RADIUS
5d02h: AAA/AUTHEN (439257908): status = GETUSER
5d02h: TTY6: Autoselect(2) sample 7E
5d02h: TTY6: Autoselect(2) sample 7EFF
5d02h: TTY6: Autoselect(2) sample 7EFF7D
5d02h: TTY6: Autoselect(2) sample 7EFF7D23
5d02h: TTY6 Autoselect cmd: ppp negotiate
5d02h: AAA/AUTHEN/ABORT: (439257908) because Autoselected.
5d02h: AAA/AUTHEN: free_user (0x1632D4) user='' ruser='' port='tty6' rem_addr='async/4889898' authen_type=ASCII service=LOGIN priv=1
5d02h: In cpm_do_call_stat_after_delay: Line protocol still not up for call at
5d02h: %LINK-3-UPDOWN: Interface Async6, changed state to up
5d02h: AAA/AUTHEN: create_user (0x163978) user='test' ruser='' port='Async6' rem_addr='async/4889898' authen_type=CHAP service=PPP priv=1
5d02h: AAA/AUTHEN/START (1564682298): port='Async6' list='' action=LOGIN service=PPP
5d02h: AAA/AUTHEN/START (1564682298): using "default" list
5d02h: AAA/AUTHEN (1564682298): status = UNKNOWN
5d02h: AAA/AUTHEN/START (1564682298): Method=RADIUS
5d02h: RADIUS: Initial Transmit id 20 65.125.219.133:1645, Access-Request, len 84
5d02h: Attribute 5 6 00000006
5d02h: Attribute 61 6 00000000
5d02h: Attribute 30 9 34383839
5d02h: Attribute 3 19 01AF40E5
5d02h: Attribute 6 6 00000002
5d02h: Attribute 7 6 00000001
5d02h: RADIUS: Received from id 20 65.125.219.133:1645, Access-Reject, len 36
5d02h: AAA/AUTHEN (1564682298): status = FAIL
5d02h: AAA/AUTHEN: free_user (0x163978) user='test' ruser='' port='Async6' rem_addr='async/4889898' authen_type=CHAP service=PPP priv=1
5d02h: Mica Modem(1/5): State Transition to Terminating
5d02h: TTY6: DSR was dropped
5d02h: tty6: Modem: READY->HANGUP
5d02h: Mica Modem(1/5): State Transition to Idle
5d02h: Mica Modem(1/5): Went onhook
5d02h: CSM_PROC_IC5_OC6_CONNECTED: CSM_EVENT_MODEM_ONHOOK at slot 1, port 5
5d02h: TDM(reg: 0x213A100): default RX connection requested.
5d02h: TDM(reg: 0x213A100): Close connection to STo6, channel 5
5d02h: TDM(reg: 0x213A100): Connect STi0, channel 5 to STo6, channel 5
5d02h: default TX connection requested.
5d02h: TDM(reg: 0x213A100): Close connection to STo0, channel 5
Any help would be appreciated
Bronze
Re: AS5248 Radius problems
The debug shows an Access-Reject reply from the RADIUS server.
The RAS sent a RADIUS packet along with the attributes for
the dial-in user. It then immediately received a reply from
the server with Access-Reject probably because some of the
attributes do not match or is not defined for the specific
user's attributes in the RADIUS server. Check the attributes
defined in the RADIUS server for this specific user.
Has this been working before? If not, try using using local
authentication first, to isolate and verify that it was caused
by the RADIUS.
Please enable "service timestamps debug datetime msec" to see
an accurate timestamps for the debug output.
Goodluck.
this is a new install...does the rest of the config look ok? Trying to use a channelized t1 with only 12 of the time slots open of the 24, still cant get in through telnet...want local authentication for telnet sessions......
Bronze
Yes, rest of the config looks fine.
I would suggest that you first perform the test without AAA.
Once successful, proceed to using AAA.
Here's a very useful link (Dial Solutions Guide):
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/dial_c/index.htm
For the telnet access using local authentication,
you have the line "aaa authentication login no_radius enable"
which will be used by the router for exec login requiring
the enable password to be entered. Just add
"login authentication no_radius" under line vty 0 4.
Goodluck.
The radius server is rejecting the user for authentication. So just fix the radius server configuration for users. Now you must be authenticating in the terminal window and after that going for "PPP" as the authentication logs have service is LOGIN. Anyway for Local authentication, configure like following
aaa authentication login default local radius
aaa authentication ppp default if-needed local radius
it will work fine.
Thank you! The radius is working good now. My configuration looks like this:
What is being attempted here is a channelized T1 with only 8 lines being used. ISDN is not in the picture.
Inow have every 5th call getting through, that is all, the other 4 calls fail. The modems answer, but can not sync up.
It insists on the Asnyc 17 through 24 instead of my Async Group 1
Any help would be appreciated. I have never run into this before, I have worked on AS5350;s 3640's etc....but not this beast...it seems a little different..
version 11.3
hostname AS5248
aaa new-model
ip subnet-zero
no ip finger
ip name-server 65.125.219.133
isdn switch-type primary-dms100
controller T1 0
cas-group 0 timeslots 16-23 type e&m-fgb mf dnis
controller T1 1
shutdown
interface Ethernet0
ip address 65.125.219.158 255.255.255.224
interface Serial0
no ip address
no ip mroute-cache
shutdown
interface Serial1
no ip address
shutdown
interface Async17
encapsulation ppp
ppp authentication pap chap
interface Async18
encapsulation ppp
interface Async19
encapsulation ppp
interface Async20
encapsulation ppp
interface Async21
encapsulation ppp
interface Async22
encapsulation ppp
interface Async23
encapsulation ppp
interface Async24
encapsulation ppp
encapsulation ppp
group-range 1 12
ip local pool ASYNC 65.125.219.147 65.125.219.157
ip classless
ip route 0.0.0.0 0.0.0.0 65.125.219.131
logging 65.125.219.157
radius-server host 65.125.219.133 auth-port 1645 acct-port 1646
line con 0
line 1 12
autoselect ppp
modem InOut
transport input all
line 13 15
line 16 23
autoselect ppp
modem InOut
transport input all
line 24 48
line aux 0
line vty 0 4
end
AS5248#
Silver
The NAS will use a round robin to assign modem for the next incomming call, in your setup, lines 1-12 & 16-23 are configured, but the asynch interfaces configured are 1-12 (group-async 1) & 17-24....this needs to be corrected to match line # & asyn interface #.
Regarding the first 4 calls not connecting, is it a cyclic pattern of 4 failures & then connects, irresepective of the modem to which they try to connect?
-debug modem
-deb modem csm (understand these are MICA modems based on outputs on your previous posts)
-debug ppp nego
To enable CAS debugging
5248#conf t
Enter configuration commands, one per line. End with CNTL/Z.
5248(config)#service internal
5248(config)#^Z
5248#modem-mgmt csm ?
debug-rbs enable rbs debugging
no-debug-rbs disable rbs debugging
5248#modem-mgmt csm debug-rbs
Do you want a setup where only a particular range of modems are used? In that case you can enable modem pooling.
Thanks, Mak.
Ok, I will make those changes, do you want me to email you the debugs or post them here?
Silver
Ideally should post them here so that others too can view them.
Thanks, Mak.
Current Config:
User Access Verification
Password:
AS5248>en
Password:
AS5248#sh run
version 11.3
service internal
hostname AS5248
aaa new-model
modem-pool POOL
ip subnet-zero
no ip finger
clock timezone Central -6
controller T1 0
controller T1 1
shutdown
interface Ethernet0
interface Serial0
no ip address
no ip mroute-cache
shutdown
interface Serial1
no ip address
shutdown
interface Async1
encapsulation ppp
interface Async2
encapsulation ppp
interface Async3
encapsulation ppp
interface Async4
encapsulation ppp
interface Async5
encapsulation ppp
interface Async6
encapsulation ppp
interface Async7
encapsulation ppp
interface Async8
encapsulation ppp
interface Async9
encapsulation ppp
interface Async10
encapsulation ppp
interface Async11
encapsulation ppp
interface Async12
encapsulation ppp
encapsulation ppp
group-range 17 24
ip classless
line con 0
password 7 082F435C1D1100051C
line 1 12
autoselect ppp
modem InOut
transport input all
line 13 15
line 16 23
autoselect ppp
modem InOut
transport input all
line 24 48
line aux 0
line vty 0 4
end
AS5248#
Debugs:
Password:
AS5248>en
Password:
AS5248#term mon
AS5248#
Feb 9 02:09:26.547: Mica Modem(1/5): State Transition to Terminating
Feb 9 02:09:27.147: Mica Modem(1/5): State Transition to Idle
Feb 9 02:09:27.151: Mica Modem(1/5): Went onhook
Feb 9 02:09:27.151: CSM_PROC_IC5_OC6_CONNECTED: CSM_EVENT_MODEM_ONHOOK at slot
1, port 5
Feb 9 02:09:27.155: neat msg at slot 0: (0/19): Tx LOOP_OPEN (AB=00)
Feb 9 02:09:27.159: VDEV_DEALLOCATE: slot 1 and port 5 is deallocated
Feb 9 02:09:39.099: neat msg at slot 0: (0/19): Rx LOOP_OPEN (AB=00)
Feb 9 02:09:58.891: neat msg at slot 0: (0/20): Rx LOOP_CLOSURE (AB=11)
Feb 9 02:09:58.935: VDEV_ALLOCATE: slot 1 and port 6 is allocated.
Feb 9 02:09:58.935: CSM_RX_CAS_EVENT_FROM_NEAT:(007A): EVENT_CALL_DIAL_IN at s
lot 1 and port 6
Feb 9 02:09:58.939: CSM_PROC_IDLE: CSM_EVENT_DSX0_CALL at slot 1, port 6
Feb 9 02:09:58.943: Mica Modem(1/6): Configure(0x0)
Feb 9 02:09:58.943: Mica Modem(1/6): Configure(0x1)
Feb 9 02:09:58.947: Mica Modem(1/6): Call Setup
Feb 9 02:09:59.063: Mica Modem(1/6): State Transition to Call Setup
Feb 9 02:09:59.067: Mica Modem(1/6): Went offhook
Feb 9 02:09:59.067: CSM_PROC_IC1_RING: CSM_EVENT_MODEM_OFFHOOK at slot 1, port
6
Feb 9 02:09:59.107: neat msg at slot 0: (0/20): Tx LOOP_CLOSURE (AB=11)
Feb 9 02:09:59.299: neat msg at slot 0: (0/20): Tx LOOP_OPEN (AB=00)
Feb 9 02:09:59.723: Mica Modem(1/6): Rcvd Digit detected(#)
Feb 9 02:09:59.903: Mica Modem(1/6): Rcvd Digit detected(4)
Feb 9 02:10:00.023: Mica Modem(1/6): Rcvd Digit detected(8)
Feb 9 02:10:00.203: Mica Modem(1/6): Rcvd Digit detected(8)
Feb 9 02:10:00.323: Mica Modem(1/6): Rcvd Digit detected(9)
Feb 9 02:10:00.443: Mica Modem(1/6): Rcvd Digit detected(8)
Feb 9 02:10:00.563: Mica Modem(1/6): Rcvd Digit detected(9)
Feb 9 02:10:00.743: Mica Modem(1/6): Rcvd Digit detected(8)
Feb 9 02:10:00.863: Mica Modem(1/6): Rcvd Digit detected(*)
Feb 9 02:10:00.867: CSM_PROC_IC2_COLLECT_ADDR_INFO: CSM_EVENT_ADDR_INFO_COLLECT
ED (DNIS=4889898, ANI=) at slot 1, port 6
Feb 9 02:10:01.935: CSM_RX_CAS_EVENT_FROM_NEAT:(007A): EVENT_CHANNEL_CONNECTED
at slot 1 and port 6
Feb 9 02:10:01.935: CSM_PROC_IC4_WAIT_FOR_CARRIER: CSM_EVENT_DSX0_CONNECTED at
slot 1, port 6
Feb 9 02:10:01.939: Mica Modem(1/6): Link Initiate
Feb 9 02:10:01.943: neat msg at slot 0: (0/20): Tx LOOP_CLOSURE (AB=11)
Feb 9 02:10:02.243: Mica Modem(1/6): Rcvd Digit detected(#)
Feb 9 02:10:02.423: Mica Modem(1/6): Rcvd Digit detected(2)
Feb 9 02:10:02.603: Mica Modem(1/6): Rcvd Digit detected(*)
Feb 9 02:10:03.023: Mica Modem(1/6): State Transition to Connect
Feb 9 02:10:07.463: Mica Modem(1/6): State Transition to Link
Feb 9 02:10:40.759: Mica Modem(1/6): State Transition to Terminating
Feb 9 02:10:41.359: Mica Modem(1/6): State Transition to Idle
Feb 9 02:10:41.363: Mica Modem(1/6): Went onhook
Feb 9 02:10:41.363: CSM_PROC_IC5_OC6_CONNECTED: CSM_EVENT_MODEM_ONHOOK at slot
1, port 6
Feb 9 02:10:41.367: neat msg at slot 0: (0/20): Tx LOOP_OPEN (AB=00)
Feb 9 02:10:41.371: VDEV_DEALLOCATE: slot 1 and port 6 is deallocated
Feb 9 02:10:53.323: neat msg at slot 0: (0/20): Rx LOOP_OPEN (AB=00)
Feb 9 02:11:22.195: neat msg at slot 0: (0/21): Rx LOOP_CLOSURE (AB=11)
Feb 9 02:11:22.239: VDEV_ALLOCATE: slot 1 and port 7 is allocated.
Feb 9 02:11:22.239: CSM_RX_CAS_EVENT_FROM_NEAT:(007B): EVENT_CALL_DIAL_IN at s
lot 1 and port 7
Feb 9 02:11:22.243: CSM_PROC_IDLE: CSM_EVENT_DSX0_CALL at slot 1, port 7
Feb 9 02:11:22.247: Mica Modem(1/7): Configure(0x0)
Feb 9 02:11:22.247: Mica Modem(1/7): Configure(0x1)
Feb 9 02:11:22.251: Mica Modem(1/7): Call Setup
Feb 9 02:11:22.395: Mica Modem(1/7): State Transition to Call Setup
Feb 9 02:11:22.395: Mica Modem(1/7): Went offhook
Feb 9 02:11:22.399: CSM_PROC_IC1_RING: CSM_EVENT_MODEM_OFFHOOK at slot 1, port
7
Feb 9 02:11:22.407: neat msg at slot 0: (0/21): Tx LOOP_CLOSURE (AB=11)
Feb 9 02:11:22.603: neat msg at slot 0: (0/21): Tx LOOP_OPEN (AB=00)
Feb 9 02:11:23.055: Mica Modem(1/7): Rcvd Digit detected(#)
Feb 9 02:11:23.235: Mica Modem(1/7): Rcvd Digit detected(4)
Feb 9 02:11:23.355: Mica Modem(1/7): Rcvd Digit detected(8)
Feb 9 02:11:23.475: Mica Modem(1/7): Rcvd Digit detected(8)
Feb 9 02:11:23.655: Mica Modem(1/7): Rcvd Digit detected(9)
Feb 9 02:11:23.775: Mica Modem(1/7): Rcvd Digit detected(8)
Feb 9 02:11:23.955: Mica Modem(1/7): Rcvd Digit detected(9)
Feb 9 02:11:24.075: Mica Modem(1/7): Rcvd Digit detected(8)
Feb 9 02:11:24.195: Mica Modem(1/7): Rcvd Digit detected(*)
Feb 9 02:11:24.195: CSM_PROC_IC2_COLLECT_ADDR_INFO: CSM_EVENT_ADDR_INFO_COLLECT
ED (DNIS=4889898, ANI=) at slot 1, port 7
Feb 9 02:11:25.239: CSM_RX_CAS_EVENT_FROM_NEAT:(007B): EVENT_CHANNEL_CONNECTED
at slot 1 and port 7
Feb 9 02:11:25.239: CSM_PROC_IC4_WAIT_FOR_CARRIER: CSM_EVENT_DSX0_CONNECTED at
slot 1, port 7
Feb 9 02:11:25.243: Mica Modem(1/7): Link Initiate
Feb 9 02:11:25.247: neat msg at slot 0: (0/21): Tx LOOP_CLOSURE (AB=11)
Feb 9 02:11:25.575: Mica Modem(1/7): Rcvd Digit detected(#)
Feb 9 02:11:25.755: Mica Modem(1/7): Rcvd Digit detected(2)
Feb 9 02:11:25.875: Mica Modem(1/7): Rcvd Digit detected(*)
Feb 9 02:11:26.355: Mica Modem(1/7): State Transition to Connect
Feb 9 02:11:30.735: Mica Modem(1/7): State Transition to Link
Feb 9 02:12:04.031: Mica Modem(1/7): State Transition to Terminating
Feb 9 02:12:04.631: Mica Modem(1/7): State Transition to Idle
Feb 9 02:12:04.635: Mica Modem(1/7): Went onhook
Feb 9 02:12:04.635: CSM_PROC_IC5_OC6_CONNECTED: CSM_EVENT_MODEM_ONHOOK at slot
1, port 7
Feb 9 02:12:04.639: neat msg at slot 0: (0/21): Tx LOOP_OPEN (AB=00)
Feb 9 02:12:04.643: VDEV_DEALLOCATE: slot 1 and port 7 is deallocated
Feb 9 02:12:16.219: neat msg at slot 0: (0/21): Rx LOOP_OPEN (AB=00)
Feb 9 02:12:45.583: neat msg at slot 0: (0/22): Rx LOOP_CLOSURE (AB=11)
Feb 9 02:12:45.627: VDEV_ALLOCATE: slot 1 and port 8 is allocated.
Feb 9 02:12:45.631: CSM_RX_CAS_EVENT_FROM_NEAT:(007C): EVENT_CALL_DIAL_IN at s
lot 1 and port 8
Feb 9 02:12:45.631: CSM_PROC_IDLE: CSM_EVENT_DSX0_CALL at slot 1, port 8
Feb 9 02:12:45.635: Mica Modem(1/8): Configure(0x0)
Feb 9 02:12:45.635: Mica Modem(1/8): Configure(0x1)
Feb 9 02:12:45.639: Mica Modem(1/8): Call Setup
Feb 9 02:12:45.787: Mica Modem(1/8): State Transition to Call Setup
Feb 9 02:12:45.791: Mica Modem(1/8): Went offhook
Feb 9 02:12:45.791: CSM_PROC_IC1_RING: CSM_EVENT_MODEM_OFFHOOK at slot 1, port
8
Feb 9 02:12:45.799: neat msg at slot 0: (0/22): Tx LOOP_CLOSURE (AB=11)
Feb 9 02:12:45.995: neat msg at slot 0: (0/22): Tx LOOP_OPEN (AB=00)
Feb 9 02:12:46.387: Mica Modem(1/8): Rcvd Digit detected(#)
Feb 9 02:12:46.627: Mica Modem(1/8): Rcvd Digit detected(4)
Feb 9 02:12:46.747: Mica Modem(1/8): Rcvd Digit detected(8)
Feb 9 02:12:46.867: Mica Modem(1/8): Rcvd Digit detected(8)
Feb 9 02:12:47.047: Mica Modem(1/8): Rcvd Digit detected(9)
Feb 9 02:12:47.167: Mica Modem(1/8): Rcvd Digit detected(8)
Feb 9 02:12:47.287: Mica Modem(1/8): Rcvd Digit detected(9)
Feb 9 02:12:47.467: Mica Modem(1/8): Rcvd Digit detected(8)
Feb 9 02:12:47.587: Mica Modem(1/8): Rcvd Digit detected(*)
Feb 9 02:12:47.591: CSM_PROC_IC2_COLLECT_ADDR_INFO: CSM_EVENT_ADDR_INFO_COLLECT
ED (DNIS=4889898, ANI=) at slot 1, port 8
Feb 9 02:12:49.011: CSM_RX_CAS_EVENT_FROM_NEAT:(007C): EVENT_CHANNEL_CONNECTED
at slot 1 and port 8
Feb 9 02:12:49.011: CSM_PROC_IC4_WAIT_FOR_CARRIER: CSM_EVENT_DSX0_CONNECTED at
slot 1, port 8
Feb 9 02:12:49.015: Mica Modem(1/8): Link Initiate
Feb 9 02:12:49.015: neat msg at slot 0: (0/22): Tx LOOP_CLOSURE (AB=11)
Feb 9 02:12:49.331: Mica Modem(1/8): Rcvd Digit detected(#)
Feb 9 02:12:49.507: Mica Modem(1/8): Rcvd Digit detected(2)
Feb 9 02:12:49.687: Mica Modem(1/8): Rcvd Digit detected(*)
Feb 9 02:12:50.107: Mica Modem(1/8): State Transition to Connect
Feb 9 02:12:54.547: Mica Modem(1/8): State Transition to Link
Feb 9 02:13:29.223: Mica Modem(1/8): State Transition to Terminating
Feb 9 02:13:29.823: Mica Modem(1/8): State Transition to Idle
Feb 9 02:13:29.823: Mica Modem(1/8): Went onhook
Feb 9 02:13:29.827: CSM_PROC_IC5_OC6_CONNECTED: CSM_EVENT_MODEM_ONHOOK at slot
1, port 8
Feb 9 02:13:29.831: neat msg at slot 0: (0/22): Tx LOOP_OPEN (AB=00)
Feb 9 02:13:29.831: VDEV_DEALLOCATE: slot 1 and port 8 is deallocated
Feb 9 02:13:41.235: neat msg at slot 0: (0/22): Rx LOOP_OPEN (AB=00)
Feb 9 02:14:24.487: neat msg at slot 0: (0/16): Rx LOOP_CLOSURE (AB=11)
Feb 9 02:14:24.531: VDEV_ALLOCATE: slot 1 and port 9 is allocated.
Feb 9 02:14:24.531: CSM_RX_CAS_EVENT_FROM_NEAT:(007D): EVENT_CALL_DIAL_IN at s
lot 1 and port 9
Feb 9 02:14:24.535: CSM_PROC_IDLE: CSM_EVENT_DSX0_CALL at slot 1, port 9
Feb 9 02:14:24.539: Mica Modem(1/9): Configure(0x0)
Feb 9 02:14:24.539: Mica Modem(1/9): Configure(0x1)
Feb 9 02:14:24.543: Mica Modem(1/9): Call Setup
Feb 9 02:14:24.655: Mica Modem(1/9): State Transition to Call Setup
Feb 9 02:14:24.659: Mica Modem(1/9): Went offhook
Feb 9 02:14:24.659: CSM_PROC_IC1_RING: CSM_EVENT_MODEM_OFFHOOK at slot 1, port
9
Feb 9 02:14:24.703: neat msg at slot 0: (0/16): Tx LOOP_CLOSURE (AB=11)
Feb 9 02:14:24.895: neat msg at slot 0: (0/16): Tx LOOP_OPEN (AB=00)
Feb 9 02:14:25.315: Mica Modem(1/9): Rcvd Digit detected(#)
Feb 9 02:14:25.555: Mica Modem(1/9): Rcvd Digit detected(4)
Feb 9 02:14:25.675: Mica Modem(1/9): Rcvd Digit detected(8)
Feb 9 02:14:25.795: Mica Modem(1/9): Rcvd Digit detected(8)
Feb 9 02:14:25.975: Mica Modem(1/9): Rcvd Digit detected(9)
Feb 9 02:14:26.095: Mica Modem(1/9): Rcvd Digit detected(8)
Feb 9 02:14:26.215: Mica Modem(1/9): Rcvd Digit detected(9)
Feb 9 02:14:26.335: Mica Modem(1/9): Rcvd Digit detected(8)
Feb 9 02:14:26.515: Mica Modem(1/9): Rcvd Digit detected(*)
Feb 9 02:14:26.519: CSM_PROC_IC2_COLLECT_ADDR_INFO: CSM_EVENT_ADDR_INFO_COLLECT
ED (DNIS=4889898, ANI=) at slot 1, port 9
Feb 9 02:14:27.531: CSM_RX_CAS_EVENT_FROM_NEAT:(007D): EVENT_CHANNEL_CONNECTED
at slot 1 and port 9
Feb 9 02:14:27.531: CSM_PROC_IC4_WAIT_FOR_CARRIER: CSM_EVENT_DSX0_CONNECTED at
slot 1, port 9
Feb 9 02:14:27.535: Mica Modem(1/9): Link Initiate
Feb 9 02:14:27.539: neat msg at slot 0: (0/16): Tx LOOP_CLOSURE (AB=11)
Feb 9 02:14:27.835: Mica Modem(1/9): Rcvd Digit detected(#)
Feb 9 02:14:28.075: Mica Modem(1/9): Rcvd Digit detected(2)
Feb 9 02:14:28.195: Mica Modem(1/9): Rcvd Digit detected(*)
Feb 9 02:14:28.615: Mica Modem(1/9): State Transition to Connect
Feb 9 02:14:33.055: Mica Modem(1/9): State Transition to Link
Feb 9 02:15:06.351: Mica Modem(1/9): State Transition to Terminating
Feb 9 02:15:06.951: Mica Modem(1/9): State Transition to Idle
Feb 9 02:15:06.955: Mica Modem(1/9): Went onhook
Feb 9 02:15:06.955: CSM_PROC_IC5_OC6_CONNECTED: CSM_EVENT_MODEM_ONHOOK at slot
1, port 9
Feb 9 02:15:06.959: neat msg at slot 0: (0/16): Tx LOOP_OPEN (AB=00)
Feb 9 02:15:06.959: VDEV_DEALLOCATE: slot 1 and port 9 is deallocated
Feb 9 02:15:19.239: neat msg at slot 0: (0/16): Rx LOOP_OPEN (AB=00)
Feb 9 02:15:50.251: neat msg at slot 0: (0/17): Rx LOOP_CLOSURE (AB=11)
Feb 9 02:15:50.295: VDEV_ALLOCATE: slot 1 and port 15 is allocated.
Feb 9 02:15:50.295: CSM_RX_CAS_EVENT_FROM_NEAT:(007E): EVENT_CALL_DIAL_IN at s
lot 1 and port 15
Feb 9 02:15:50.299: CSM_PROC_IDLE: CSM_EVENT_DSX0_CALL at slot 1, port 15
Feb 9 02:15:50.303: Mica Modem(1/15): Configure(0x0)
Feb 9 02:15:50.303: Mica Modem(1/15): Configure(0x1)
Feb 9 02:15:50.307: Mica Modem(1/15): Call Setup
Feb 9 02:15:50.447: Mica Modem(1/15): State Transition to Call Setup
Feb 9 02:15:50.451: Mica Modem(1/15): Went offhook
Feb 9 02:15:50.451: CSM_PROC_IC1_RING: CSM_EVENT_MODEM_OFFHOOK at slot 1, port
15
Feb 9 02:15:50.463: neat msg at slot 0: (0/17): Tx LOOP_CLOSURE (AB=11)
Feb 9 02:15:50.659: neat msg at slot 0: (0/17): Tx LOOP_OPEN (AB=00)
Feb 9 02:15:51.047: Mica Modem(1/15): Rcvd Digit detected(#)
Feb 9 02:15:51.287: Mica Modem(1/15): Rcvd Digit detected(4)
Feb 9 02:15:51.407: Mica Modem(1/15): Rcvd Digit detected(8)
Feb 9 02:15:51.527: Mica Modem(1/15): Rcvd Digit detected(8)
Feb 9 02:15:51.707: Mica Modem(1/15): Rcvd Digit detected(9)
Feb 9 02:15:51.827: Mica Modem(1/15): Rcvd Digit detected(8)
Feb 9 02:15:51.947: Mica Modem(1/15): Rcvd Digit detected(9)
Feb 9 02:15:52.127: Mica Modem(1/15): Rcvd Digit detected(8)
Feb 9 02:15:52.247: Mica Modem(1/15): Rcvd Digit detected(*)
Feb 9 02:15:52.251: CSM_PROC_IC2_COLLECT_ADDR_INFO: CSM_EVENT_ADDR_INFO_COLLECT
ED (DNIS=4889898, ANI=) at slot 1, port 15
Feb 9 02:15:53.567: CSM_RX_CAS_EVENT_FROM_NEAT:(007E): EVENT_CHANNEL_CONNECTED
at slot 1 and port 15
Feb 9 02:15:53.571: CSM_PROC_IC4_WAIT_FOR_CARRIER: CSM_EVENT_DSX0_CONNECTED at
slot 1, port 15
Feb 9 02:15:53.571: Mica Modem(1/15): Link Initiate
Feb 9 02:15:53.575: neat msg at slot 0: (0/17): Tx LOOP_CLOSURE (AB=11)
Feb 9 02:15:53.867: Mica Modem(1/15): Rcvd Digit detected(#)
Feb 9 02:15:54.107: Mica Modem(1/15): Rcvd Digit detected(2)
Feb 9 02:15:54.227: Mica Modem(1/15): Rcvd Digit detected(*)
Feb 9 02:15:54.647: Mica Modem(1/15): State Transition to Connect
Feb 9 02:15:59.087: Mica Modem(1/15): State Transition to Link
Feb 9 02:16:33.347: Mica Modem(1/15): State Transition to Terminating
Feb 9 02:16:33.947: Mica Modem(1/15): State Transition to Idle
Feb 9 02:16:33.951: Mica Modem(1/15): Went onhook
Feb 9 02:16:33.951: CSM_PROC_IC5_OC6_CONNECTED: CSM_EVENT_MODEM_ONHOOK at slot
1, port 15
Feb 9 02:16:33.955: neat msg at slot 0: (0/17): Tx LOOP_OPEN (AB=00)
Feb 9 02:16:33.955: VDEV_DEALLOCATE: slot 1 and port 15 is deallocated
Feb 9 02:16:46.139: neat msg at slot 0: (0/17): Rx LOOP_OPEN (AB=00)
Feb 9 02:17:14.011: neat msg at slot 0: (0/18): Rx LOOP_CLOSURE (AB=11)
Feb 9 02:17:14.055: VDEV_ALLOCATE: slot 1 and port 16 is allocated.
Feb 9 02:17:14.055: CSM_RX_CAS_EVENT_FROM_NEAT:(007F): EVENT_CALL_DIAL_IN at s
lot 1 and port 16
Feb 9 02:17:14.059: CSM_PROC_IDLE: CSM_EVENT_DSX0_CALL at slot 1, port 16
Feb 9 02:17:14.059: Mica Modem(1/16): Configure(0x0)
Feb 9 02:17:14.063: Mica Modem(1/16): Configure(0x1)
Feb 9 02:17:14.063: Mica Modem(1/16): Call Setup
Feb 9 02:17:14.203: Mica Modem(1/16): State Transition to Call Setup
Feb 9 02:17:14.207: Mica Modem(1/16): Went offhook
Feb 9 02:17:14.207: CSM_PROC_IC1_RING: CSM_EVENT_MODEM_OFFHOOK at slot 1, port
16
Feb 9 02:17:14.223: neat msg at slot 0: (0/18): Tx LOOP_CLOSURE (AB=11)
Feb 9 02:17:14.419: neat msg at slot 0: (0/18): Tx LOOP_OPEN (AB=00)
Feb 9 02:17:14.863: Mica Modem(1/16): Rcvd Digit detected(#)
Feb 9 02:17:15.043: Mica Modem(1/16): Rcvd Digit detected(4)
Feb 9 02:17:15.163: Mica Modem(1/16): Rcvd Digit detected(8)
Feb 9 02:17:15.343: Mica Modem(1/16): Rcvd Digit detected(8)
Feb 9 02:17:15.463: Mica Modem(1/16): Rcvd Digit detected(9)
Feb 9 02:17:15.643: Mica Modem(1/16): Rcvd Digit detected(8)
Feb 9 02:17:15.763: Mica Modem(1/16): Rcvd Digit detected(9)
Feb 9 02:17:15.883: Mica Modem(1/16): Rcvd Digit detected(8)
Feb 9 02:17:16.063: Mica Modem(1/16): Rcvd Digit detected(*)
Feb 9 02:17:16.067: CSM_PROC_IC2_COLLECT_ADDR_INFO: CSM_EVENT_ADDR_INFO_COLLECT
ED (DNIS=4889898, ANI=) at slot 1, port 16
Feb 9 02:17:17.051: CSM_RX_CAS_EVENT_FROM_NEAT:(007F): EVENT_CHANNEL_CONNECTED
at slot 1 and port 16
Feb 9 02:17:17.055: CSM_PROC_IC4_WAIT_FOR_CARRIER: CSM_EVENT_DSX0_CONNECTED at
slot 1, port 16
Feb 9 02:17:17.059: Mica Modem(1/16): Link Initiate
Feb 9 02:17:17.059: neat msg at slot 0: (0/18): Tx LOOP_CLOSURE (AB=11)
Feb 9 02:17:17.323: Mica Modem(1/16): Rcvd Digit detected(#)
Feb 9 02:17:17.563: Mica Modem(1/16): Rcvd Digit detected(2)
Feb 9 02:17:17.683: Mica Modem(1/16): Rcvd Digit detected(*)
Feb 9 02:17:18.163: Mica Modem(1/16): State Transition to Connect
Feb 9 02:17:22.543: Mica Modem(1/16): State Transition to Link
Feb 9 02:17:55.839: Mica Modem(1/16): State Transition to Terminating
Feb 9 02:17:56.439: Mica Modem(1/16): State Transition to Idle
Feb 9 02:17:56.443: Mica Modem(1/16): Went onhook
Feb 9 02:17:56.443: CSM_PROC_IC5_OC6_CONNECTED: CSM_EVENT_MODEM_ONHOOK at slot
1, port 16
Feb 9 02:17:56.447: VDEV_DEALLOCATE: slot 1 and port 16 is deallocated
Feb 9 02:17:56.499: neat msg at slot 0: (0/18): Tx LOOP_OPEN (AB=00)
Feb 9 02:18:08.223: neat msg at slot 0: (0/18): Rx LOOP_OPEN (AB=00)
Connection to host lost.
It is little to troubleshoot this issue here. So pl. open a tac case by logging at
www.cisco.com/tac to resolve this issue.
176
