AS5300 call drop problem
I am doing some testing with an application programmer who has an app that dials in from a PC to an AS5300. The PC is using a USR_Sportster modem, and the access server has a single ISDN PRI circuit. Here is the line config for the modem pool we are using:
line 4 8
no motd-banner
no exec-banner
no flush-at-activation
no vacant-message
modem Dialin
modem autoconfigure type usr_sportster
autocommand telnet HOSTNAME /quiet /noecho
transport preferred none
transport input all
transport output pad telnet rlogin udptn
escape-character NONE
telnet transparent
autohangup
dispatch-timeout 250
I can watch his PC connect (debug isdn q931) and then disconnect with the following messages:
ISDN Se0:23: TX -> DISCONNECT pd = 8 callref = 0x9DD9
Cause i = 0x8090 - Normal call clearing
ISDN Se0:23: RX <- RELEASE pd = 8 callref = 0x1DD9
ISDN Se0:23: TX -> RELEASE_COMP pd = 8 callref = 0x9DD9
He then gets a fast busy signal - like all circuits busy. Any suggestions?
Also, when I run "debug modem" I can see the access server saying "autoconfigure probe started" on each TTY line. I assume this is normal since I am using "modem autoconfigure type " in my config?
Dan
Re: AS5300 call drop problem
Wanted to include the call setup as well . . .
ISDN Se0:23: RX <- SETUP pd = 8 callref = 0x1DD9
Bearer Capability i = 0x9090A2
Channel ID i = 0xA98381
Net Specific Fac i = 0x00E2
Called Party Number i = 0xA1, '200', Plan:ISDN, Type:National
ISDN Se0:23: TX -> CALL_PROC pd = 8 callref = 0x9DD9
ISDN Se0:23: TX -> ALERTING pd = 8 callref = 0x9DD9
When watching the modem pool, the modem appears to connect, then the call drops and the dialing party gets a fast busy signal. Any suggestions would be greatly appreciated.
Dan
Bronze
Hi Dan,
I think I may have misinterpreted something in a previous message. You now mention the remote modem is a USR sportster, but what modems do you have locally (I thought the local modems were USR)?
If you do have external USR modems attached to the 5300, than the config is OK.
But if they are built-in modems (NM-xDM modules) then the modem type should be mica.
Don't know if this solves the disconnect though.
If it doesn't, try debug confmodem.
regards
Herbert
They are internal Mica modems. I was able to find information on CCO that helped me resolve the issue: I modified the line config to read "modem InOut" instead of just "modem In". That seemed to do the trick.
Thanks again for your input.
dk
127
