Webcast-Catalyst9k
AS5300 Dialout and busying modems when T1 interface goes down
I am trying to identify a way to configure the AS5300 so when the T1 interface goes down the modems are considered "busy", therefore, rendering dialout as unavailable. Currently, if the T1 goes down the modems still appear available from the dialout perspective using port 5001. The connection hangs and does not return an error message. I would also expect the modems to come out of "busy" at the time the T1 status becomes up and stable.
I am not using DDR on this device. I am supporting both inbound and outbound dial needs for a group within my company. I am running 12.2.6 IOS and 2.7.3.0 on my mica modems.
Thanks.
Paul Haering
1 REPLY
Re: AS5300 Dialout and busying modems when T1 interface goes dow
There is no way to reflect the T1's status on modems availability automatically. You need to busyout modems manually if T1 is not available for dialout.
89
