No, we cannot get primary clock (from line) on each E1/ T1 port on the same NAS. The primary clock source is to clock the TDM bus . Only one source is capable of clocking the bus, hence the reason for the primary / secondary / network-clock-select and other various IOS commands.
Whenever you are connected to multiple T1 providers on the same NAS, it is recommended to set your T1's to recover clocking from the most accurate source. In you case you will need to talk to the providers to sort this out.
http://www.cisco.com/warp/public/116/sgl_clocking.html
Thanks, Mak.
