Community Member
AS5300 ---> console connection but will not ask for a login
I am connected to a as5300 through the console port and when I hit return to enter the system it tells me to hit return to continue. I hit return and it tells me again to hit return. I captured the following:
%SYS-4-CONFIG_NEWER: Configuration from version 12.1 may not be correctly unders
tood
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
uhhs-as5300 con0 is now available
Press RETURN to get started.
1 REPLY
Anonymous
N/A
Re: AS5300 ---> console connection but will not ask for a login
Can you telnet to the router? If not, you
will need to break into the router
during boot up to get access to the config.
You want to verify the minimum config is
there; ensure that "no exec" is NOT
configured.
106
