Community Member
AS5300 IOS UPGRADING PROBLEM
hi
I have problem . i m uploading IOS via Ronmon but error are as follow.
Frist status is :::
System Bootstrap, Version 12.0(2)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
AS5300 platform with 131072 Kbytes of main memory
loadprog: error - trouble reading file magic number
open: failed to find and/or load the bootloader: "bootflash:c5300-js-mz.123-15.b
in"
loadprog: error - on file open
boot: cannot load "cisco2-AS5300"
device does not contain a valid magic number
boot: cannot open "flash:"
boot: cannot determine first file name on device "flash:"
boot: cannot load "bootflash:"
and mem info is :::::::::
rommon 1 > meminfo
Main memory size: 128 MB. Packet memory size: 16 MB
Available main memory starts at 0xa000e000, size 0x7ff2000
Packet memory starts at 0xa8000000
NVRAM size: 0x20000
when I run commond Xmodem than errors comes
1) transfer canceled by remote system.
and 2nd ::::::::::::
modem c5300-is-mz.122-17.bin
Do not start the sending program yet...
File size Checksum File name
0 bytes (0x0) 0xffff c5300-js-mz.123-15.bin
WARNING: All existing data in bootflash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
Ready to receive file c5300-is-mz.122-17.bin ...
BB0
ERR:Image size exceeds free flash space
rommon 3 >
plz check the thing and advice.
Silver
Re: AS5300 IOS UPGRADING PROBLEM
You are trying to load an image that is to large for your flash filesystem. Try another image, upgrade your flash memory or boot via TFTP.
Leon
* Please rate useful posts.
Hall of Fame Super Gold
The poster originally posted exactly this same question on the WAN Routing and Switching forum where it has gotten a couple of responses. I suggest that we consolidate the discussion on that forum.
Rick
133
