AS5300 Multi PPP authenacation
I am a small ISP service and having problems with ISDN customers who are using 128 k to connect. All the 56k customers can log in fine. If I set the ISDN customers to 64k one line use they can log in but they don't get to use their second line. If I set their connection to 128k they can't log in? Here is some of my configuartion to look at:
Any thougths where the error is would be great.
controller T1 0
framing esf
clock source line primary
linecode b8zs
pri-group timeslots 1-24
controller T1 1
framing esf
clock source internal
linecode b8zs
controller T1 2
framing esf
linecode b8zs
controller T1 3
shutdown
framing esf
linecode b8zs
interface Loopback0
ip address
interface Tunnel1
no ip address
ip mtu 1476
interface Ethernet0
no ip address
shutdown
interface Serial0:23
no ip address
encapsulation ppp
no ip route-cache
dialer rotary-group 1
dialer-group 1
isdn switch-type primary-ni
isdn incoming-voice modem
no peer default ip address
no fair-queue
no cdp enable
interface Serial1:23
no ip address
encapsulation ppp
no ip route-cache
dialer-group 1
no fair-queue
no cdp enable
interface Serial2:23
no ip address
encapsulation ppp
no ip route-cache
no keepalive
shutdown
dialer-group 1
no fair-queue
no cdp enable
interface Serial3:23
no ip address
encapsulation ppp
dialer-group 1
isdn switch-type primary-5ess
peer default ip address pool default
ppp authentication chap pap ms-chap
ppp multilink
interface FastEthernet0
ip address
no ip mroute-cache
duplex full
interface Group-Async1
ip unnumbered FastEthernet0
encapsulation ppp
no ip mroute-cache
dialer in-band
dialer idle-timeout 1800
async mode dedicated
no cdp enable
ppp authentication pap chap ms-chap
group-range 1 48
interface Dialer1
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer in-band
dialer idle-timeout 2147483 either
dialer load-threshold 1 either
dialer-group 1
no fair-queue
no cdp enable
ppp authentication pap chap ms-chap callin
ppp multilink
Re: AS5300 Multi PPP authenacation
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
i want to ask you a question
why you addes command ppp multilink in interface Serial3:23
and you did not add it to the others .please try to add this command to all of the interfaces .
111
