AS5300 problem using ISDN
We have an AS5300 configured for POTS and ISDN backup. the as5300 is configured with two PRI's. When I shut down the frame interface on one of my 2610's it should dial out to the as5300 and the isdn should come up. However you never see the ISDN on the 2610 connect to the access server with both PRI's up. When I shut down the second PRI and leave one up the ISDN works fine. I have also called out from the access server to the 2610 with both pri's up and you never see the call connecting. Both Pri's are configured the same. see below:
interface Serial0:23
description S0:23 Verizon ISDN ***REMOVED***
no ip address
encapsulation ppp
dialer rotary-group 0
dialer-group 1
isdn switch-type primary-5ess
isdn incoming-voice modem
no fair-queue
no cdp enable
ppp authentication chap
ppp multilink
interface Serial1:23
description s1:23 Verizon secondary ***REMOVED***
no ip address
encapsulation ppp
shutdown
dialer-group 1
no fair-queue
no cdp enable
ppp multilink
As you can see I have shutdown interface Serial1:23 in order for ISDN to work on the AS5300. Im curios as to what the problem could be. My show ISDN status shows that i have Multiple frame established and my spids are valid. However this second isdn ckt seems to be causing some sort of conflict with the other. Thanks in Advance for any input provided.
-CMV
Re: AS5300 problem using ISDN
I assume that you be using "backup interface .." command for backup. Command "shutdown" will not activate the back as "shutdown" leaves the primary inteface in "adminisratively down" mode.
In order to test the backup, you need to bring the layer 1 down by removing the cable from the primary interface port OR change the encapsulation type to bing the layer 2 down.
Another thing to make sure that, you need to have interesting traffic defind. Also that interesting traffic will activate the backup line to dialout once the primary line is down. so we need to see the running config for "interface dialer 0" from the PRI router and the relevent config from 2610 router.
If the config is fine, then we need to see the debug for following
debug dialer
debug isdn q931
debug ppp nego
debug ppp auth
term mon
from the router receiving the call and also from the router originating the call.
interface Dialer0
description For ISDN base routers
ip address ***REMOVED***
encapsulation ppp
dialer in-band
dialer idle-timeout 60
dialer map ip ***REMOVED***
dialer-group 1
no fair-queue
no cdp enable
ppp chap hostname rwdb1-as5300
ppp chap password ***REMOVED***
Here is the 2610 config:
interface BRI0/0
description BRI ISDN Ckt#
ip address **REMOVED***
encapsulation ppp
dialer string 17326022341
dialer string 19727920229
dialer load-threshold 240 either
dialer-group 1
isdn switch-type basic-ni
isdn spid1 70367156430101 6715643
isdn spid2 70367156440101 6715644
no cdp enable
ppp chap hostname rdca2-0011
ppp multilink
rwdb1-as5300#debug isdn events
ISDN events debugging is on
rwdb1-as5300#term mon
rwdb1-as5300#ping 10.10.240.37
Sending 5, 100-byte ICMP Echos to 10.10.240.37, timeout is 2 seconds:
*Feb 3 23:20:48.955 utc: Se1:23 DDR: rotor dialout [priority]
*Feb 3 23:20:48.955 utc: Se1:23 DDR: place call
*Feb 3 23:20:48.955 utc: Se1:23 DDR: Dialing cause ip (s=10.10.240.5, d=10.10.)
*Feb 3 23:20:48.955 utc: Se1:23 DDR: Attempting to dial 17039793574
*Feb 3 23:20:48.955 utc: ISDN Se1:23: Outgoing call id = 0x840A, dsl 1
*Feb 3 23:20:48.955 utc: ISDN Se1:23: Event: Call to 17039793574 at 64 Kb/s
*Feb 3 23:20:48.955 utc: ISDN Se1:23: process_pri_call(): call id 0x840A, numbf
*Feb 3 23:20:48.955 utc: callED type/plan overridden by call_decode
*Feb 3 23:20:48.959 utc: did't copy oct3a reason: not CALLER_NUMBER_IE
*Feb 3 23:20:48.959 utc: building outgoing channel id for call nfas_int is 0 0
*Feb 3 23:20:49.083 utc: ISDN Se1:23: LIF_EVENT: ces/callid 1/0x840A CALL_PROCG
*Feb 3 23:20:49.083 utc: ISDN Se1:23: CALL_PROCEEDING id 0x840A
*Feb 3 23:20:49.083 utc: ISDN Se1:23: PRI Event: 6, bchan = 22, call type = DAA
*Feb 3 23:20:50.191 utc: ISDN Se1:23: LIF_EVENT: ces/callid 1/0x840A CALL_DISC
*Feb 3 23:20:50.191 utc: ISDN Se1:23: process_disc_ack(): call id 0x840A, ces F
*Feb 3 23:20:50.235 utc: ISDN Se1:23: CCPRI_ReleaseCall(): bchan 23, call id 0A
*Feb 3 23:20:50.235 utc: CCPRI_ReleaseChan released b_dsl 1 B_Chan 23
*Feb 3 23:20:50.235 utc: ISDN Se1:23: LIF_EVENT: ces/callid 1/0x840A CALL_CLEAD
*Feb 3 23:20:50.235 utc: ISDN Se1:23: received CALL_CLEARED call_id 0x840A
*Feb 3 23:20:50.235 utc: no resend setup, no redial
*Feb 3 23:20:50.235 utc: no resend setup, no redial.
Success rate is 0 percent (0/5)
rwdb1-as5300#
Also one thing I should mention, the AS5300 always worked fine UNTIL the second pri was put in. I think my config is tight but maybe I have a connectivity issue, regardless the other pri should at least work. The strange part to me is that by shutting down the one pri on the as5300 seems to "fix" the issue.
Here is the debug off the router 2610
5d22h: BR0/0 DDR: Dialing cause ip (s=**REMOVED**, d=**REMOVED**)
5d22h: BR0/0 DDR: Attempting to dial 17326022341
5d22h: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x1E
5d22h: Bearer Capability i = 0x8890
5d22h: Channel ID i = 0x83
5d22h: Keypad Facility i = '17326022341'
5d22h: ISDN BR0/0: RX <- CALL_PROC pd = 8 callref = 0x9E
5d22h: Channel ID i = 0x89..
5d22h: ISDN BR0/0: RX <- PROGRESS pd = 8 callref = 0x9E
5d22h: Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-
5d22h: Signal i = 0x01 - Ring back tone on
5d22h: ISDN BR0/0: HOST_PROGRESS: Got IE of INBAND or Not End-To-End.
Thank you
-CMV
Its very strange that by shutting down the new PRI line, the calls between 5300 and 2610 works fine for both the direction.
I do not see the CONNECT at the isdn q931 layer so I think the debug you have posted is not if full. We only need to see the debug for following in order to see the clear issue. Enable that on the router receiving the call and originating the call too.
debug dialer
debug ppp nego
debug isdn q931
debug ppp authentication
That way we can verify that the call is originated and forwarded to the terminating router. You can also follow the link below for more isdn troubleshooting
http://www.cisco.com/warp/public/471/isdn_q931_ts.html
Here are the debugs you requested, and again thank you for your help. I removed ips and replaced with the appropriate hostname.
rwdb1-as5300#ping 2610 router
Sending 5, 100-byte ICMP Echos to 2610 router, timeout is 2 seconds:
May 20 14:30:49.215 utc: Di0 DDR: No free dialer - starting fast idle timer.
May 20 14:30:51.215 utc: Di0 DDR: No free dialer - starting fast idle timer.
May 20 14:30:53.215 utc: Di0 DDR: No free dialer - starting fast idle timer.
May 20 14:30:55.215 utc: Di0 DDR: No free dialer - starting fast idle timer.
May 20 14:30:57.215 utc: Di0 DDR: No free dialer - starting fast idle timer.
rwdb1-as5300#sho debug
Dial on demand:
Dial on demand events debugging is on
PPP:
PPP authentication debugging is on
PPP protocol negotiation debugging is on
ISDN:
ISDN Q931 packets debugging is on
ISDN Q931 packets debug DSLs. (On/Off/No DSL:1/0/-)
DSL 0 --> 7
1 1 - - - - - -
I have never seen this message before about the no free dialer. I have nothing on the access server right now.
Here is the one from the 2610. THis is all I get.
rdca2-0011#debug dialer
rdca2-0011#debug ppp negotiation
rdca2-0011#debug isdn q931
rdca2-0011#debug ppp auth
rdca2-0011#term mon
rdca2-0011#ping AS-5300
Sending 5, 100-byte ICMP Echos to AS-5300 , timeout is 2 seconds:
6d03h: BR0/0 DDR: Dialing cause ip (s=2610router, d=as5300)
6d03h: BR0/0 DDR: Attempting to dial 17326022341
6d03h: ISDN BR0/0: TX -> SETUP pd = 8 callref = 0x20
6d03h: Bearer Capability i = 0x8890
6d03h: Channel ID i = 0x83
6d03h: Keypad Facility i = '17326022341'
6d03h: ISDN BR0/0: RX <- CALL_PROC pd = 8 callref = 0xA0
6d03h: Channel ID i = 0x89...
6d03h: ISDN BR0/0: RX <- PROGRESS pd = 8 callref = 0xA0
6d03h: Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-
6d03h: Signal i = 0x01 - Ring back tone on
6d03h: ISDN BR0/0: HOST_PROGRESS: Got IE of INBAND or Not End-To-End..
As you can see the call is not getting forward at the isdn layer. So you can talk to local provider about the outgoing call. Also have you seen that the call is even showed up pr received at as5300.
If not, then again something is really wrong with the circuit.
Thanks for all your help again. I really appreciate it. I have called out the PRI giving me trouble to the provider to test. I guess I dont really understand why I would still have layer 2 up on the sh isdn status. I will post telco results. Luckily we have someone from cisco coming here today to discuss eigrp maybe he knows isdn as well :)
-CMV
Bronze
make sure the line has been provisoned to send and receive calls.
Telco tested good, im back to where I started. I sat there and watched the verizon tech do loops and pattern tests on his t-berd and all passed. Im more convinced than before now that its a config issue on the as-5300. All the trunks on the PRI are working. I think I will just open a tac case with cisco now. Thanks for your help
-CMV
157
