Webcast-Catalyst9k
AS5300 problem
Hi, we have been using AS5300 and it was working smoothly.
But since last week costomers has been complaining about slow browsing and they get connected in low speed e.g at 4800bps,2400bps.They have to try again and again to get satisfactory speed.
Can you please suggest me what may be the actual problem, and how to trouble shoot this kind of problem??
Ishwar
Re: AS5300 problem
I am assuming they are using MICA modems, are you using any modemcap?
post config, and we can have a look..
Re: AS5300 problem
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
Here is the conf file.Please have a look
version 12.0
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime localtime
service password-encryption
hostname router
no logging console
aaa new-model
aaa authentication login sysadm line
aaa authentication login line1-240 radius
aaa authentication ppp default if-needed radius
aaa authorization network default radius if-authenticated
aaa accounting update newinfo
aaa accounting network default start-stop radius
aaa nas port extended
clock timezone NST 5 45
modem country mica e1-default
modem recovery threshold 50
ip subnet-zero
no ip finger
ip domain-name mos.com.np
ip name-server xxx.xx.255.47
ip name-server xxx.xx.255.3
controller E1 0
framing NO-CRC4
clock source line primary
line-termination 75-ohm
cas-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
answer-guard-time 1
controller E1 1
framing NO-CRC4
clock source line secondary 1
cas-custom 1
answer-guard-time 1
controller E1 2
framing NO-CRC4
clock source line secondary 2
cas-custom 1
answer-guard-time 1
controller E1 3
framing NO-CRC4
clock source line secondary 3
cas-custom 1
answer-guard-time 1
controller E1 4
framing NO-CRC4
clock source line secondary 4
cas-custom 1
answer-guard-time 1
controller E1 5
framing NO-CRC4
clock source line secondary 5
cas-custom 1
answer-guard-time 1
controller E1 6
framing NO-CRC4
clock source line secondary 6
cas-custom 1
answer-guard-time 1
controller E1 7
framing NO-CRC4
clock source line secondary 7
cas-custom 1
answer-guard-time 1
interface Loopback0
description DO NOT TOUCH THIS IP ADDRESS
ip address xxx.xx.227.161 255.255.255.255
no ip directed-broadcast
interface Ethernet0
description ****** NPIX SWITCH ******
ip address 192.168.0.2 255.255.255.0 secondary
ip address xxx.xx.231.68 255.255.255.192 secondary
ip address xxx.xx.228.185 255.255.255.252
ip access-group peer-in in
ip access-group peer-out out
interface Serial0
description CONNECTED TO DMG-3640.SERIAL2/0 (2Mb Patton)
ip address xxx.xx.228.2 255.255.255.252
no ip route-cache
ip ospf cost 100
no ip mroute-cache
no fair-queue
interface Serial1
description CONNECTED TO DMG-3640.SERIAL2/1
ip address xxx.xx.228.6 255.255.255.252
no ip route-cache
ip ospf cost 100
no ip mroute-cache
no fair-queue
interface Serial2
description CONNECTED TO DMG-3640 SERIAL2/2
ip address xxx.xx.228.10 255.255.255.252
no ip route-cache
ip ospf cost 100
no ip mroute-cache
no fair-queue
interface Serial3
description CONNECTED TO DMG-3640 SERIAL2/3
ip address xxx.xx.228.14 255.255.255.252
no ip route-cache
ip ospf cost 100
no ip mroute-cache
no fair-queue
interface FastEthernet0
description CROSSOVER TO SDR-2620
ip address xxx.xx.250.253 255.255.255.0
ip ospf cost 10
speed 10
interface Group-Async0
ip unnumbered Loopback0
ip access-group 101 in
ip access-group internet out
encapsulation ppp
no logging event link-status
async mode interactive
peer default ip address pool pool0
ppp max-bad-auth 3
ppp authentication pap
group-range 1 240
hold-queue 10 in
router ospf 1
redistribute static subnets
passive-interface default
no passive-interface FastEthernet0
no passive-interface Serial0
no passive-interface Serial1
no passive-interface Serial2
no passive-interface Serial3
network xxx.xx.227.161 0.0.0.0 area 0
network xxx.xx.228.2 0.0.0.0 area 0
network xxx.xx.228.6 0.0.0.0 area 0
network xxx.xx.228.10 0.0.0.0 area 0
network xxx.xx.228.14 0.0.0.0 area 0
network xxx.xx.228.185 0.0.0.0 area 0
network xxx.xx.250.253 0.0.0.0 area 0
ip local pool pool0 xxx.xx.250.1 xxx.xx.250.240
no ip http server
ip classless
no ip prefix-list sequence-number
radius-server host xxx.xx.255.70 auth-port 1645 acct-port 1646 non-standard
radius-server timeout 10
-- moderator edit --
^C
line con 0
transport input none
line 1 240
exec-timeout 5 0
no flush-at-activation
autoselect during-login
autoselect ppp
login authentication line1-240
modem InOut
modem autoconfigure type default
autocommand ppp
transport input all
line aux 0
line vty 0 4
access-class 11 in
exec-timeout 5 0
password 7 xxxxxxxxxxxxxxxxxxxxx
login authentication sysadm
escape-character 43
ntp clock-period 17179720
ntp peer xxx.xx.255.25
end
164
