AS5300 Problem
derrick.joseph
I currently have an AS5300 Cisco router for my E1R2 dialup connections. My problem is, some of my dialup users have difficulty in establishing connection due to these errors:
Line User Host(s) Idle Location
2 tty 2 Virtual Exec 00:00:00
3 tty 3 Virtual Exec 00:00:00
4 tty 4 Virtual Exec 00:00:00
5 tty 5 Virtual Exec 00:00:00
6 tty 6 Virtual Exec 00:00:00
7 tty 7 user1 Async interface 00:00:00 PPP: xxx.yyy.zzz.aaa
8 tty 8 user2 Async interface 00:00:12 PPP: xxx.yyy.zzz.aab
9 tty 9 user3 Async interface 00:05:47 PPP: xxx.yyy.zzz.aba
10 tty 10 user4 Async interface 00:00:00 PPP: xxx.yyy.zzz.baa
As a result, some of my terminal ports are unavailbe due to Virtual Execs. What I wanted to know are:
1. what are the causes of the following problems ?
2. what are the solutions for these problems ?
3. how can i get rid of the following problems ?
I haven't encountered a problem such as this one before and what im doing is to reload or power off the router so that it will disappear.
Thanks.
makchitale
Level 6
Level 6
This is a known issue...what IOS image are you running on the as5300?
CSCdp33819 "TTY lines process virtual-exec is running, no user dialed in" is Resolved in 12.1 later images.
Thanks, Mak.
Sir,
Here is the IOS version of my RAS. This problem started last 3 months, my concern is, I have been using this RAS for the past 4 years and I haven't encountered a problem such as the one I'm having.
Are there any solutions for this problem aside from upgrading the IOS ? Where can I get an IOS, can you provide me with one :) ?
IOS (tm) 5300 Software (C5300-I-M), Version 12.0(7)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Wed 08-Dec-99 21:00 by phanguye
Image text-base: 0x600088F8, data-base: 0x607D4000
ROM: System Bootstrap, Version 12.0(2)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTFLASH: 5300 Software (C5300-BOOT-M), Version 12.0(4)T1, RELEASE SOFTWARE (fc1)
ras1 uptime is 1 day, 6 hours, 38 minutes
System returned to ROM by reload at 17:52:36 PHILIPP Thu Jul 27 2000
System image file is "flash:c5300-i-mz.120-7.T.bin"
cisco AS5300 (R4K) processor (revision A.32) with 65536K/16384K bytes of memory.
Processor board ID 15266266
R4700 CPU at 150Mhz, Implementation 33, Rev 1.0, 512KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 2.0, Item Number 800-2544-3,
Board Revision B0, Serial Number 15266266,
PLD/ISP Version 0.0, Manufacture Date 8-Oct-1999.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
60 terminal line(s)
4 Channelized E1/PRI port(s)
128K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
Derrick
