Webcast-Catalyst9k
AS5350 and ISDN/PRI question
I have an AS5350 with a PRI. I want to be able to dial out via the PRI and I want to use 2 of the 23 B channels (128k) to connect to an ISDN modem on the other end. Basically I want to be able to dial a PRI to remote BRI (128k ISDN circuit). Is this possible with just the AS5350?
My other options witch I know will work is to either send the PRI into Adtran Atlas 800 to channelize it, or just get a router that supports mulitple BRI U's and forget the PRI all together.
Any help or input will be greatly appreciated.
1 REPLY
Bronze
Re: AS5350 and ISDN/PRI question
Yes, this is possible. It could be done via standard DDR and a dialer map. If you want to limit the connections to 2, then you could use dialer profiles, OR "ppp mult link max 2", OR "username foo user-maxlink 2".
267
