Webcast-Catalyst9k
AS5350 problem with asyncronous calls after failure of the PRI line
I have an AS5350 running 12.2(XB) .Each time my PRI line fails, asyncronous calls cannot be established to the AS5350 until a reload is performed.After the reload everything is ok.
Anu help would be greatly appreciated.
Silver
Re: AS5350 problem with asyncronous calls after failure of the P
After PRI fails & comes back up, can we get ISDN calls to connect?
Before the reload, need to see the following:
sh isdn status / sh isdn service / sh controller t1 / show spe
At what stage does the modem call fail?
deb isdn q931 / deb modem / deb csm modem / deb ppp nego
Thanks, Mak.
Unfortunately Ican't supply the information You requested now, because I have reloaded the device- its very important to be available all the time for incoming connections.
I apply here the output of the command: sh spe
Settings :
Country code config : default T1 (u Law)
Country code setting: e1-default
History log events : 50(per port)
Legend :
Port state: (s)shutdown (r)recovery (t)test (a)active call
(b)busiedout (d)download (B)bad (p)busyout pending
Call type : (m)modem (d)digital (v)voice (f)fax-relay (_)not in use
Summary :
Ports : Total 60 In-use 0 Free 60 Disabled 0
Calls : Modem 0 Digital 0 Voice 0 Fax-relay 0
SPE SPE SPE SPE Port Call
SPE# Port # State Busyout Shut Crash State Type
1/00 0000-0005 ACTIVE 0 0 0 ______ ______
1/01 0006-0011 ACTIVE 0 0 0 ______ ______
1/02 0012-0017 ACTIVE 0 0 0 ______ ______
1/03 0018-0023 ACTIVE 0 0 0 ______ ______
1/04 0024-0029 ACTIVE 0 0 0 ______ ______
1/05 0030-0035 ACTIVE 0 0 0 ______ ______
1/06 0036-0041 ACTIVE 0 0 0 ______ ______
1/07 0042-0047 ACTIVE 0 0 0 ______ ______
1/08 0048-0053 ACTIVE 0 0 0 ______ ______
1/09 0054-0059 ACTIVE 0 0 0 ______ ______
104
