Webcast-Catalyst9k
Ask for how to use cisco 2525 5in1 WAN module
i am confused about the 2525 Five-in-One serial port module, only one DB60 port, why is called 5 in 1?
meanwhile, if the DB60 serial port works, can I connect to 2501? just like DCE-to-DTE?
1 REPLY
Re: Ask for how to use cisco 2525 5in1 WAN module
5 in 1 means that the port supports 5 phisycal standards, RS-232/V.35/X.21/RS-449/RS-530, on the port. Which standard the port functions in depends on the cable that is plugged into de port. This is 5 in 1.
Yes, you can connect to another 2501 using a pair of cables DTE/DCE.
Cheers
98
