Webcast-Catalyst9k
SAC
ASR1001-X Multi-chassis LAG support
Does ASR1001-X with IOS-XE 3.13S3 supports Multi-Chassis LAG?
Everyone's tags (3)
Bronze
By themselves, no.  But if
By themselves, no.  But if the neighboring device does (Nexus VPC, VSS, switch stack, etc) then they can do a port channel bundle.
SAC
Thanks Johnny. Any idea if
Thanks Johnny. Any idea if the limitation is on the code and there are plans in future to add this feature or some sort of hardware limitations? Any link/doc which can provide details.
Bronze
I'm definitely not the best
I'm definitely not the best person to ask as I don't work for Cisco and have zero hands-on experience with the ASR platform.  Lack of LAG support was the main reason I'm still using 6500s w/ VSS for edge routing.
169
