Asymmetric routing and MSFC msg
After seeing Unicast flooding due to Asymmetric routing we had to adjust the ARP timeout to match the CAM aging time. Changing the CAM aging time to
144400 seconds solved the problem But when we try to do it other way and
decrease ARP timeout as recommnded to 300secs. we started to get following mesages. Has anybody seen this msg before? what is best way to stop Unicast flooding adjusting ARP timeout or CAM aging time?
InCharge Domain : DFM MSFC MSFC-AO-MCR1-SS-1-15 PerformanceException -
System is experiencing Port or Interface performance problems.
InCharge Domain : DFM Interface IF-MSFC-AO-MCR1-SS-1-15/7 [Vl172]
HighQueueDropRate - The number of packets discarded due to input or output
queue overflow has exceeded its threshold.
InCharge Domain : DFM MSFC MSFC-AO-MCR1-SS-2-15 PerformanceException -
InCharge Domain : DFM Interface IF-MSFC-AO-MCR1-SS-2-15/8 [Vl172]
1 REPLY
Re: Asymmetric routing and MSFC msg
The preferable method is to change the MAC aging time to 14,400 seconds. Are you seeing any messages on the MSFC..Check for any high input/output rate on your VLAN interfaces. Here is an explanation for the message you are seeing in the DFM
High Queue Drop rate fault is reported if the number of packets discarded due to input or output queue overflow exceeds the Queue Drop Threshold. The input (or output) queue overflow is derived by dividing the number of packets designated to be sent (or received) that were discarded due to queue overflow by the total number of packets in the queue.
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/dfm/dfm1_1/u_g/faults.htm#61297
114
