Async dial backup / help urgent please
I have a headache about async dial backup. I have 2 site connected by leased line. Headquarter includes 2600, remote office has 1601. I will use 2600's Aux port and 1601's default sync/async port for backup. Remote office will call headquarter when main line gets down. I prepared a demo, Async interfaces get up when I disconnect main line. But there is no IP traffic, even when I open CDP there is no CDP traffic. I even checked arp cache.
Configs:
1) Headquarter
sh run
Building configuration...
Current configuration : 1137 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname MERKEZ
enable secret 5 $1$n8.8$Cw8wPkdtvLQtaLm0ZxKhw0
ip subnet-zero
no ip domain-lookup
modemcap entry MY_USR_MODEM:MSC=&F1S0=1
interface Ethernet0/0
half-duplex
interface Serial0/0
backup delay 15 15
backup interface Async65
ip address 10.0.0.1 255.0.0.0
encapsulation ppp
interface Async65
ip address 172.16.1.1 255.255.0.0
encapsulation ppp
keepalive 10
dialer in-band
dialer idle-timeout 10000
dialer-group 1
async default routing
async dynamic routing
async mode dedicated
no fair-queue
router rip
network 10.0.0.0
network 172.16.0.0
network 192.168.0.0
no auto-summary
ip classless
no ip http server
ip pim bidir-enable
access-list 101 permit ip any any
dialer-list 1 protocol ip permit
no cdp run
line con 0
password servus
login
line aux 0
modem Dialin
modem autoconfigure type MY_USR_MODEM
transport input all
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
password servus
login
end
Remote Office: (Caller - 1601)
sh run
Current configuration:
version 11.3
hostname BOLGE
enable secret 5 $1$S/.z$uKg.xPJ1YCQqC7eH18L5..
ip subnet-zero
no ip domain-lookup
chat-script CALLOUT ABORT ERROR ABORT BUSY "" "AT" OK "ATDT \T" TIMEOUT 45 CONNECT \c
interface Ethernet0
ip address 192.168.2.1 255.255.255.0
interface Serial0
physical-layer async
description --- BACKUP INTERFACE ---
ip address 172.16.1.2 255.255.0.0
encapsulation ppp
keepalive 10
dialer in-band
dialer string 311
dialer-group 1
async mode interactive
no fair-queue
interface Serial1
description --MAIN INTERFACE--
backup delay 15 15
backup interface Serial0
ip address 10.0.0.2 255.0.0.0
encapsulation ppp
clockrate 64000
router rip
network 10.0.0.0
network 172.16.0.0
network 192.168.0.0
no auto-summary
ip classless
no cdp run
line con 0
password servus
login
line 1
autoselect ppp
script dialer CALLOUT
modem InOut
transport input all
stopbits 1
speed 115200
line vty 0 4
password servus
login
end
I debug all, see on headqurter router is that:
As65 IPCP: TIMEout: State REQsent
As65 IPCP: PPP Phase is TERMINATING, discarding packet
PS. from remote office I can ping 172.16.1.2 (itself), but on headquarter in can' t ping itself.(172.16.1.1)!!!!!!!!!!
thanx
Re: Async dial backup / help urgent please
I think you need to loose the 'async dynamic routing' command on both ends. Give that a try and let us know if you still have problems. Since you also have 'async default routing' I'm not sure which one is in force. Default routing is the default behavior on aux ports.
I also think you need to change 'async mode interactive' to 'async mode dedicated' on the remote router.
I have changed and tried the new configs. But it's useless.Is it impossible to backup from 1601 Serial 0 to 2600 Aux port???
Silver
Try removing the backup interface command from S0/0 on the 2600, when you enter this command it places async interface 65 into a backup state where it will be unable to receive calls unless the main interface (S0/0) has also failed. Normally you only use this command on the router performing the dailup (1601) and leave the receiving router configured normally for dial in.
Theres an example of this on CCO at:
http://www.cisco.com/warp/public/793/access_dial/async_backup_14281.html
hello,
I have even tried to remove backup interface from 2600 headquarter router.No solution
I noticed that when the primary line is up, on 2600 async interface seems up and spoofing, but 1600 ser0 (async interface) is in standby mode. When I check your link, it' s said that it should be up&spoofing when primary is up???
The 1600 should be in standby and the 2600 should be spoofing when the primary line is up. The link that was given earlier shows what you need to do next, which is get your static routes entered. You need two static routes on your 1600 and a floating static route on your 2600.
104
