Webcast-Catalyst9k
async dial problem
i have one 3740 router,local authentication,but when i dial,
the profile display "no answer",and dial again display "it's busy",and use the command "show modem log 4/0" display follow:
00:01:48.372 RS232: CTS DSR noDCD noRI* noRxBREAK TxBREAK
00:01:48.368 Hook state: Off hook
00:01:46.268 Modem State: Waiting for Carrier
00:00:46.532 Modem State: Disconnecting
00:00:46.532 CSM: event-MODEM_DISCONNECTED New State-IDLE_STATE
00:00:46.524 End connection: Retransmits for MNP block (TX/RX) = 0/0
Duration = 0:00:00, Number of TX/RX char = 0/172
Local Disc Reason = No carrier
Remote Disc Reason = Unknown
00:00:48.292 Hook state: On hook
00:00:48.008 RS232: CTS DSR noDCD RI* noRxBREAK TxBREAK
00:00:47.436 RS232: CTS DSR noDCD noRI* noRxBREAK TxBREAK
00:00:47.432 Modem State: Idle
00:00:45.992 RS232: CTS DSR noDCD noRI* noRxBREAK TxBREAK
00:00:45.988 Modem State: Dialing/Answering
00:00:45.988 CSM: event-MODEM_STARTING_CONNECT New State-CSM_CONNECT_INITIATED_S
TATE
00:00:45.336 Modem State: Incoming ring
00:00:45.336 CSM: event-MODEM_ANALOG_CALL_IN New State-CSM_CONNECT_INITIATED_STA
TE
00:00:45.176 RS232: CTS DSR noDCD noRI* noRxBREAK TxBREAK
00:00:45.172 Hook state: Off hook
00:00:43.064 Modem State: Waiting for Carrier¡Â
i do not know why there is no carrier,could you tell me?
Bronze
Re: async dial problem
Which direction is the call going ? Into the 3700 or dialing out from the 3700 ? Please describe the dial process that is taking place. What kind of trunk are you using PRI, or CAS ? Capture debug cas or debug isdn q931 in addition to debug modem csm and debug modem to get a better look.
Daniel
and i dial into 3700,
and i use debug modem trace all,display as follow:
Mar 1 01:32:23.271: %MODEM_HIST-3-END_CALL: MCOM Modem 4/0
Connect Protocol - Unkn, Compression - Unkn, Connected Standard - Unkn
Tx/Rx bit rate - 0/0
Call Time - 00:00:00, Disconnect Reason (0x2) - No carrier
0/0 retrains initiated/accepted, 0/0 speedshifts initiated/accepted
0 chars tx, 4248 chars rx
*Mar 1 01:33:28.295: %MODEM_HIST-3-END_CALL: MCOM Modem 4/0
0 chars tx, 4425 chars rx
93
