Async Interface Problem
Dear All,
We have a RAS setup at our Central Office.
To setup the RAS network we are using Cisco 2514 router with 8 async interface.
To each async interface we have connected external Dlink modem.
Users were able to dial-in from remote location using windows dialup and external modem , and use to access the central site LAN from the assigned IP Pool configured in the central site router.
Problem we are facing now is that all the async lines are working but the Async interface is not coming UP.
Is this a IOS related bug.
Sample config for singe async interface is as given below
Hostname RAS
enable password cisco
interface Ethernet0
ip address 10.5.55.35 255.255.255.240
no ip directed-broadcast
no ip route-cache
interface Async1
ip unnumbered Ethernet0
encapsulation ppp
no ip route-cache
keepalive 10
async mode interactive
peer default ip address 10.10.8.231
ppp authentication pap
line con 0
exec-timeout 0 0
password xxxx
transport input none
line 1 8
modem InOut
transport input all
rxspeed 57600
txspeed 57600
flowcontrol hardware
line aux 0
modem InOut
transport input all
line vty 0 4
!end
Any suggestion is welcomed
Silver
Re: Async Interface Problem
Can you please explain what do you mean by "Problem we are facing now is that all the async lines are working but the Async interface is not coming UP"...do you mean by "working" means remote users can dialin & connect fine? OR do you mean that the call does not connect at all?
In the later case will need to see some debugs on the 2514: deb modem / deb ppp nego
Unless we have a complete PPP call terminated on the 2514 we will not see the interface asyn1 as UP/UP.
If we are to add the command "dialer in-band" (basically required if we need to dial out) under interface asyn1 then we will see the status as UP/UP(spoofing) without a call connected.
Thanks,Mak.
Calls get connected but disconnect immediately i.e Async interface comes up for few seconds and while the remote dialup client is in authentication mode async interface resets (Goes down) while authenticating remote client.
Neither it throws IP to the remote client.
Deepak
Silver
We will need to see the following debugs on the router when a call is made & fails:
Thanks,Mak.
You have missed some config steps in line mode . With your configuration router side modem CD ( Carrier ditect ) will not reflect on your router and line gets disconnected and async interface will not come up. CD is reflected on PC and Router for speed sync.
you try with this config
interface ethernet 0
ip address 10.11.1.1 255.255.255.0
interface Group-Async1
encapsulation ppp
peer default ip address pool zoom
group-range 1 16
ip local pool zoom 10.11.1.215 10.11.1.226
ip classless
line con 0
line 1 16
autoselect ppp
login local
modem InOut
modem autoconfigure discovery
transport input all
Rourer(Config)#username zoom password zoom
hope it will help you
Tried the posted config but still while authenticating the remote client async interface resets.(State of the interface changes from UP to reset and Down).
Remote Client not getting authenticated.
Correction Router is 2509
Tested the posted config , observed that after putting modem autoconfigure discovery it started working.
thanks.
160
