Ata flash card failure on 6509
6509 and native ios 12.1(8b) ,ata flash card can't work;
format slot0:
error message:
6509#format slot0
Format operation may take a while. Continue? [confirm]
Format operation will destroy all data in "slot0:". Continue? [confirm]
Enter volume ID (up to 64 chars)[default slot0]:
%Error formatting slot0 (Bad device info block)
Re: Ata flash card failure on 6509
If you have another 6509, check the same to see if the card has gone bad.
Bronze
Hi, if it is an ata flash card then it will be disk0:
What size is it?
ata flash card size is 64M
Bronze
Use the command format disk0: for any device over 32MB.
Also, the 64MB PCMCIA ATA Flash card requires Supervisor Engine 2 with ROMMON software release 7.1(1).
hth
292
