ATM and Dialer config for ADSL WIC for Newbie
Cisco 2621 w/ 1-port ADSL WIC running Cisco IOS 12.2(11)T1
Getting following errors after setting up atm 0/0 and Dailer:
00:04:05: %DIALER-6-BIND: Interface Vi4 bound to profile Di1
00:04:05: %LINK-3-UPDOWN: Interface Virtual-Access4, changed state to up
00:04:07: %DIALER-6-UNBIND: Interface Vi4 unbound from profile Di1
00:04:29: %DIALER-6-BIND: Interface Vi5 bound to profile Di1
00:04:29: %LINK-3-UPDOWN: Interface Virtual-Access5, changed state to up
00:04:31: %DIALER-6-UNBIND: Interface Vi5 unbound from profile Di1
At one point I saw a message about "Cannot connect, dialer string not set". Not sure what to put for dialer string as I'm taking off an example config the ISP provided. I show their sample config after my config.
Here's the config on my router:
Current configuration : 1510 bytes
version 12.2
service config
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname cnb
enable secret 5 $1$n4u4$6a65dMJNFNayGDSJyZj8U0
enable password 7 02040D4F080E
username cnb privilege 15 password 7 045F1E0403284216
ip subnet-zero
ip name-server 159.134.237.6
ip name-server 159.134.237.17
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
voice call carrier capacity active
mta receive maximum-recipients 0
interface ATM0/0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5snap
pppoe-client dial-pool-number 1
dsl operating-mode auto
no fair-queue
interface FastEthernet0/0
ip address 62.77.170.72 255.255.255.0
speed auto
half-duplex
no cdp enable
interface FastEthernet0/1
ip address 192.168.0.2 255.255.255.0
no ip proxy-arp
no ip route-cache
no ip mroute-cache
speed auto
half-duplex
no cdp enable
interface Dialer1
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer pool 1
dialer remote-name redback
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname cnb
ppp chap password 7 06021A2340470741
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip pim bidir-enable
access-list 1 permit any
dialer-list 1 protocol ip list 1
no call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password 7 104C080A1116000F
login
end
ISP Sample Configuration:
Building configuration...
Current configuration : 1257 bytes
version 12.2
no service pad
hostname frankblack-gw
enable secret 5 $1$DNOj$g7.98XMP1rAlvPSih/Sbrfht0
username frankblack privilege 15 password 7 094NB4O10T61H70PP
ip subnet-zero
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface ATM0
no ip address
pvc 8/35
no fair-queue
ip address 10.77.171.129 255.255.255.248
ip tcp adjust-mss 1452
speed auto
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname frankblack
ppp chap password 7 1N5O17P0A3SE2SE75W
ip classless
no ip http server
! ! access-list 10 permit 10.77.171.128 0.0.0.7 access-list 10 permit 159.134.222.0 0.0.1.255 dialer-list 1 protocol ip list 1 !
line con 0
exec-timeout 50 0
password 7 08N64O410W10YB
login
stopbits 1
line aux 0
line vty 0 4
access-class 10 in
exec-timeout 5 0
login local
length 0
scheduler max-task-time 5000
end
Bronze
Re: ATM and Dialer config for ADSL WIC for Newbie
Here's a link to the access technical tips. There are some additional links at the bottom with helpful debug information.
http://www.cisco.com/warp/public/471/index.shtml
Turns out that the ISP hadn't set up our login yet or routed our IP range.
232
