ATM IMA problem on 3825 router
I am upgrading the router hardware from a 3620 to a 3825 router. I am running ATM IMA with 4 T1 bundle. The existing router (3620) has been running fine, but when I switch to the new router 3825, I can't bring up the ATM interfaces (the 4 T1). But when i switch back to the old router, it works fine.
The config basically is identical between the two.
I am puzzle what went wrong. is the ATM service provider need to do anything on their end?
Any suggestion on this would be greatly appreciated.
Re: ATM IMA problem on 3825 router
Check the clocking if they are configured.
network-clock-participate
network-clock-select
Please rate all posts.
I configured this as follows:
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate aim 0
network-clock-select 1 T1 0/0/0
network-clock-select 2 T1 0/0/1
network-clock-select 3 T1 0/1/0
network-clock-select 4 T1 0/1/1
it turns out to be the service provider has to re-provision their circuit on their ATM switches. After that, all works well.
Thanks all your help.
119
