Community Member
ATM IMA problem on 7200
Hi I have 7200 router. this is output of sh ver
IOS (tm) 7200 Software (C7200-IS-M), Version 12.2(6c)M1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 15-Mar-02 05:15 by pwade
Image text-base: 0x600089C0, data-base: 0x61390000
ROM: System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb 117], DEVEL
OPMENT SOFTWARE
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.1(8a)E, EARLY DEPLOYMENT RELE
ASE SOFTWARE (fc1)
Router uptime is 4 weeks, 3 days, 8 hours, 20 minutes
System returned to ROM by reload at 08:31:23 UTC Fri May 9 2003
System image file is "disk0:c7200-is-mz.122-6c.M1.bin"
cisco 7204VXR (NPE225) processor (revision A) with 114688K/16384K bytes of memor
y.
Processor board ID 23653927
R527x CPU at 262Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
4 slot VXR midplane, Version 2.1
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
10 ATM network interface(s)
125K bytes of non-volatile configuration memory.
46976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
I have running 3640 with ATM IMA and everything is working ok. I must replace it with 7200, but when I try to move ATM IMA links to 7200, link is down with IMA status insufucient links.
Any ideas? Does anyone have sample config for ATM IMA on 7200
Thanks!
Re: ATM IMA problem on 7200
first of all, make sure that all physical parameters (Framing, linecode, scrambling, ...) are correct on the 7200 ATM interfaces. What is the status of the ATM interfaces on the 7200 ? What is that 7200 connected to ?
Community Member
1. I do not know to what 7200 is conneted at provider side but following config is ok on my 3640, same physical lines
interface ATM2/6
no ip address
no ip mroute-cache
no atm ilmi-keepalive
ima-group 1
scrambling-payload
impedance 120-ohm
interface ATM2/7
no ip address
no ip mroute-cache
ima-group 1
scrambling-payload
impedance 120-ohm
interface ATM2/IMA1
bandwidth 2048
ip address x.x.x.x x.x.x.x
no atm oversubscribe
pvc line x/x
protocol ip x.x.x.x broadcast
ubr 2048
encapsulation aal5snap
ima clock-mode common 7
2. When I do following config on 7200
interface ATM1/6
no ip address
scrambling cell-payload
framing crc4adm
ima-group 1
interface ATM1/7
no ip address
framing crc4adm
ima-group 1
interface ATM1/ima1.1 point-to-point
bandwidth 2048
ip address 10.199.2.1 255.255.255.252
pvc line x/x
protocol ip x.x.x.x
ubr 2000
oam-pvc manage 0
I get following status on ima group
Router#sh ima int atm1/ima1
ATM1/ima1 is down
ImaGroupState: NearEnd = startUp, FarEnd = insufficientLinks
ImaGroupFailureStatus = insufficientLinksFe
IMA Group Current Configuration:
ImaGroupMinNumTxLinks = 1 ImaGroupMinNumRxLinks = 1
ImaGroupDiffDelayMax = 190 ImaGroupNeTxClkMode = common(ctc)
ImaGroupFrameLength = 128 ImaTestProcStatus = disabled
ImaGroupTestLink = 6 ImaGroupTestPattern = 0xFF
IMA Link Information:
Link Link Status Test Status
ATM1/6 down disabled
ATM1/7 down disabled
Note that I cannot write ubr 2048 on pvc and that interfaces atm1/6 and atm1/7 looks ok if they are not in ima group, but after putting them in ima group I get following status
Router#sh int atm1/6
ATM1/6 is down, line protocol is down
Hardware is IMA PA
MTU 4470 bytes, BW 1920 Kbit, DLY 100 usec,
reliability 0/255, txload 1/255, rxload 1/255
Encapsulation UNKNOWN, loopback not set
Encapsulation(s): AAL5
511 maximum active VCs, 0 current VCCs
VC idle disconnect time: 300 seconds
2 carrier transitions
Last input never, output never, output hang never
Queueing strategy: Per VC Queueing
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Community Member
... and also i get following message durin router boot
%PA-2-UNDEFPA: Undefined Port Adaptor type 187 in bay 1
%PA-3-DEACTIVATED: port adapter in bay [1] powered off.
bay 1 is a bay with ATM card
Community Member
A couple of things, verify with provider, sequence # on the t1's, it matters.
Secondly i did not see the ima group defined, try this
What's your total bandwidth? is it 2 E1's
interface ATM1/6
no ip address
framing crc4adm
ima-group 0
interface ATM1/7
no ip address
framing crc4adm
ima-group 0
interface ATM1/IMA0
description *** IMA-GROUP 0 ATM 1/6 1/7-1 2-T1's ***
mtu 1500
bandwidth 2048
no ip address
load-interval 30
no atm auto-configuration
no atm address-registration
no atm ilmi-enable
interface ATM1/ima0.1 point-to-point
bandwidth 2048
pvc line x/x
protocol ip x.x.x.x
ubr 2000
oam-pvc manage 0
Good Luck
Kevin
Community Member
It looks like you have an IMAM version mismatch. 7200 implements IMAM 1.1, but 3640 supports IMAM 1.0. So you need to call your provider and let them know you change to IMAM 1.0, they will probably need to restart the IMAM group in order to renegotiation take place between Router and switch (in some switches IMAM version should be change manually).
Unfortunately this is one part of the problem. In the old times when ATM Forum made the recommendation for IMAM development USA Vendors misinterpreted them. So there are 2 variants of IMAM 1.0 one apply by most of American Vendors and an other by Europeans. The differences are on how TX/RX Link IDs should be assign (you can read more about this at: Cisco Bug CSCdw74417). There are two possibilities to workaround this problem, some switches like Lucent SAX may be configure for any of the two variants. The other one is to connect port 1 of router with port 1 of switch, 2 with 2 and so on.
But in any case you need to call your provider and let them know, if you are unable to reach some one at your provider who understands about IMAM, just tell him to restart de IMAM group.
More info at: http://www.cisco.com/en/US/tech/tk39/tk356/technologies_tech_note09186a008009455b.shtml
Good Luck
Lucas
Community Member
You need to have an Enterprise IOS to support IMA modules.
Community Member
... or maybe problem is that on
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_module_installation_guide_chapter09186a0080107335.html#1030921
is written
"The PA-A3-IMA in a Cisco 7200 VXR router requires the NPE-300, 4 MB of SRAM,
and a minimum of 64 MB of DRAM"
and I have NPE-255
možda je to
172
