ATM IMA using multiple point-to-point T1s
pmorehead
Can a pair of 2610 routers with T1 ATM IMA module be configured for point to point T1s (instead of ATM) to connect to another 2610 with T1 ATM IMA module?
doug.lockwood
T-1 IMA cards can be used over point-to-point T-1's, without using an ATM switch. If I understand correctly, the 2600 routers are limited to PVC only. It takes a 3600 series router to run clip or lane. However, PVC's are most approprate over dedicated lines, in any case. I want to look up wheather the 2610 supports the IMA card, however.
If you are interested, I have 2 IMA cards for the 2600/3600 in the IO Lab in Arlington Heights.
Doug
the 2610 does support IMA cards; just took one out of service.
