ATM interface MTU
We have 7206 with ENHANCED ATM PA - OC3 adapter.
I parsed "sh int atm 1/0 "thru the "Otput nterpreter":
https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl
and got the warning (see the EOM for the outputs) that the MTU is high (the default MTU for this interface is 4470. Is there a reason to change the MTU size in this case. We are running PPPeE on ATM for our ADSL custommers.
Thanks a lot,
Val
sh int atm 1/0 output:
ATM1/0 is up, line protocol is up
Hardware is ENHANCED ATM PA
MTU 4470 bytes, sub MTU 4470, BW 149760 Kbit, DLY 80 usec,
Encapsulation ATM, loopback not set
Keepalive not supported
Encapsulation(s): AAL5
4096 maximum active VCs, 188 current VCCs
VC idle disconnect time: 300 seconds
0 carrier transitions
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:08:35
Queueing strategy: Per VC Queueing
5 minute input rate 121000 bits/sec, 43 packets/sec
5 minute output rate 492000 bits/sec, 62 packets/sec
29909 packets input, 8937192 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
3 input errors, 3 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
39014 packets output, 35151690 bytes, 0 underruns
Otput nterpreter warning:
Interface ATM1/0 (up/up)
WARNING: The MTU is high.
TRY THIS: On AIP, use the smallest MTU you can, preferably 1500. Set it on all
subinterfaces and also on the main interface.
The MTU is very important on AIP, since it directly affects the number of
available buffers in MEMD and on the AIP itself.
VIP-based ATM port adapters are not as affected, since they use fixed size
particles instead of MTU size buffers and VIPs are much faster in draining
packets from MEMD.
Be careful - changing MTU on a 7500 will cause a CBUS restart.
During CBUS restart, all the interfaces will go down/up, since SRAM buffers are
reassigned to all the interfaces. The router will not switch any packets for
approximately 20-30 seconds.
Re: ATM interface MTU
For PPPoE connection, MTU size should be 1492 as documented at
http://www.cisco.com/warp/public/794/router_mtu.html
So if you are terminating the PPPoE connection on the aggregator 7200, you need to have "mtu 1492" under the "interface virtual-template 1"..See following url for config on 7200
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t1/dtpppoe.htm#28158
TEJAL,
Thank you for the reply.
Yes, MTU of the "virtual-template" is 1492.
My question was about the ATM interface.
Anyway, thanks a lot again,
Val
MTU for ATM interface is defaults to 4470..(maximum mtu on that interface). You should not modify the mtu size at atm layer..At ip protocol later mtu should be 1492....
Changing the MTU value with the mtu interface configuration command can affect values for the protocol-specific versions of the command (ip mtu for example). If the value specified with the ip mtu interface configuration command is the same as the value specified with the mtu command and you change the value for the mtu command, the ip mtu value automatically matches the new mtu value. However, changing the value for the ip mtu command has no effect on the value for the mtu command.
Tejal,
thanks again for the detailed answer. The reason I'm asking these questions about MTU is the problem I have with our ADSL customers. Please see this my post:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.ee81a01
Val
1023
