Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
ATM layer help on Cisco 827
I am trying to configure my Cisco 827 to access my isp using PPPOE with dynamic IP. But i have problem establishing a connection. VPI/VCI = 0/100.
Any assistance would be appreciated.
I have done something debug and this is what i get.
NAT: dialer not up for Dialer1, no translation, dial and drop
00:02:03: IP: s=10.10.10.2 (Ethernet0), d=165.21.100.88 (Dialer1), g=165.21.100.88, len 65, forward
00:02:03: Di1 DDR: ip (s=10.10.10.2, d=165.21.100.88), 65 bytes, outgoing uninteresting (no dialer-group defined)
00:02:03: DDR: 45000041 29C20000 7F11F470 0A0A0A02 A5156458 04050035
00:02:03: DDR: 002D1C59 004A0100 00010000 00000000 0B6D736E 62632D7A
00:02:03: Di1 DDR: dialer_fsm_idle()
00:02:03: IP: s=10.10.10.2 (Ethernet0), d=165.21.100.88 (Dialer1), len 65, encapsulation failed
00:02:04: IP: NAT enab = 1 trans = 0 flags = 80
00:02:04: NAT: dialer not up for Dialer1, no translation, dial and drop
00:02:04: IP: s=10.10.10.2 (Ethernet0), d=165.21.100.88 (Dialer1), g=165.21.100.88, len 65, forward
00:02:04: Di1 DDR: ip (s=10.10.10.2, d=165.21.100.88), 65 bytes, outgoing uninteresting (no dialer-group defined)
00:02:04: DDR: 45000041 29C30000 7F11F46F 0A0A0A02 A5156458 04050035
00:02:04: DDR: 002D1C59 004A0100 00010000 00000000 0B6D736E 62632D7A
00:02:04: Di1 DDR: dialer_fsm_idle()
00:02:04: IP: s=10.10.10.2 (Ethernet0), d=165.21.100.88 (Dialer1), len 65, encapsulation failed
00:02:04: ILMI(ATM0): No ILMI VC found
00:02:04: ILMI: Encapsulation error on o/g ILMI Pdu <ilmi_send_pkt> (ATM0)
00:02:04: ILMI: Unable to Send Pdu out <ilmi_send_trap>
00:02:04: Sending PADI: vc=0/100
00:02:04: pppoe_send_padi:
00 01 00 00 AA AA 03 00 80 C2 00 07 00 00 FF FF
FF FF FF FF 00 04 27 FD 73 E1 88 63 11 09 00 00
00 0C 01 01 00 00 01 03 00 04 81 00 A2 E8 00 ...
00:02:04:
00:02:04: c820_vc_tx_start: idb = 0x80D85EE0, cos_queue = 0x80C8CE14
00:02:04: c820_aal_send: pak = 0x80E67F94, vc = 0d, q = 1
00:02:04: pquicc_sar_pak2txring: nextTxBd = 0x80C8CB1C, ring = 0x80C8C954
00:02:04: pquicc_sar_add_pak_tx: packet TX=0x1F783FC, len=70, oam?=0
00:02:04: TX interrupt: conid 2, usedTxBd: Shadow 0x80C8CB1C, Real 0x80DBB5D0
00:02:04: pquicc_sar_safe_start: vc = 1
00:02:04: padi timer expired
My config file
service timestamps debug uptime
service timestamps log uptime
hostname Router
ip subnet-zero
vpdn enable
vpdn-group ppoe
request-dialin
protocol pppoe
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/100
pppoe-client dial-pool-number 1
dsl operating-mode auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication pap callin
ppp pap sent-username XXXX password XXXX
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
access-list 1 permit 10.10.10.0 0.0.0.255
1 REPLY
Re: ATM layer help on Cisco 827
Does that PVC number 0/100 is correct? Enable "debug atm packet" and see if 827 receive any atm packets from isp on that pvc. Pl. double check with isp about that pvc number. Anyway here is the url which will help you to troubleshoot further.
http://www.cisco.com/warp/customer/794/827pppoe_client.html
Also
http://www.cisco.com/warp/customer/794/adslguide_pppoeof.html
255
