ATM multipoint connection to ATM point-to-point
We are planning to lose connectivity through the one PVC after we reconfigure the local site connection with a point-to-point. We want to leave the hub router configured as a multipoint connection. Will this work? We plan to do this using these commands:
no interface ATMx/IMA0.1 multipoint
*reload router*
interface ATMx/IMA0.1 point-to-point
description ~text
bandwidth ~value
ip address x.x.x.x 255.255.255.252
ip pim sparse-mode
pvc 1/100
vbr-nrt ~xxxx yyyy 250
oam-pvc manage 15
oam retry 15 15 1
2. After we change the hub side as a point-to-point connection, is it ok to leave the local site pvc's configured as point-to-point and one as a multipoint connection for a couple weeks? Will it have any detrimental affect on multicast or unicast traffic?
show version:
IOS (tm) 3600 Software (C3640-IS-M), Version 12.1(11), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Tue 02-Oct-01 20:56 by kellythw
Image text-base: 0x60008940, data-base: 0x60E96000
ROM: System Bootstrap, Version 11.1(19)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
lav2607gw1 uptime is 16 weeks, 1 day, 15 hours, 20 minutes
System restarted at 01:22:10 CST Wed Nov 12 2003
System image file is "flash:c3640-is-mz.121-11.bin"
cisco 3640 (R4700) processor (revision 0x00) with 74752K/7168K bytes of memory.
Processor board ID 08357351
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
2 FastEthernet/IEEE 802.3 interface(s)
8 ATM network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
1 REPLY
Re: ATM multipoint connection to ATM point-to-point
As long as the PVC to IP mappings on the other end are maintained, you should be fine. If you are running OSPF on this link, you need to put ip ospf network point-to-point on the multipoint side so the adjacency will form.
226
