ATM PVC issue.
I have vlan 1 configured on my Catalyst 5000 with an Ip address of 10.1.1.1/24 assigned to interface sc0. I have IP address 10.1.1.2/24 assigned to int atm 2/0.1 on my 7200 router. I have an ATM LANE blade in my Catalyst 5000 (which is connected back-to-back to the 7200) and I want to be able to ping from one side to the other across the ATM link.
I have tried:
Catalyst 5000:
session 5 (to get onto ATM LANE blade)
interface atm0.1 point-to-point
atm pvc 3 1 100 aal5snap
atm bind pvc vlan 3 1
7200:
interface atm 2/0.1 point-to-point
ip address 10.1.1.2 255.255.255.0
pvc 1/100
encapsulation aal5snap
When I try the ping from 7200 to Catalyst 5000, the pings time out and on the ATM LANE blade it shows an error for each ping as follows:
Number of received Frame dropped due to bad AAL5 length 10:
Anyone know what is going wrong? I have tried all I can think of!
Darren.
Re: ATM PVC issue.
The cat5k is going to send ethernet packets in AAL5snap frames while the router expects IP frames. You have to configure the router for IRB or RBE.
More information at the following URLs:
http://www.cisco.com/warp/customer/121/19.html
http://www.cisco.com/warp/customer/121/#h
Re: ATM PVC issue.
Just tried that and it works a treat - thanks!
Re: ATM PVC issue.
hello,
i'm glad to hear it works now.
i was wondering what if you will use "atm routed-bridged ip" under the point-to-point interface on 7200 ...
thank you,
mihai
89
