ATM single mode fiber IR to LR connection
Hello all,
I submitted this question to CCO-open forum:
Can I connect Two Routers, First 7513 with ATM Single mode Long REACH module ( PA-A3-OC3SML ) and the Second 3661 with ATM Single mode Intermediate Reach module
I have a direct fiber cable between the two routers and distance between them is 2 Km
Thanks for your help
and I got this reply from them:
Answer submitted by a Cisco CCIE engineer -
You can do it but be careful with the power-budgets. You may have to put an attenuator on the LR transmitter.
Now my question is:
both my router ATM intface is up and line protocol is up too
but I have no iput in both sides...
and I could not even ping the other side...
Please can anyone help me in this
Regards,,
Magdy
  • Other Network Infrastructure Subjects
Re: ATM single mode fiber IR to LR connection
Magdy,
If your interfaces are both up and up, and you are sending from both sides but not receiving, then contact your service provider for a test assist with a NOC engineer. Send pings from both boxes, considering you have access to both at the same time, and have the engineer verify that he/she can see traffic at both ends. If your interfaces are up, physical hardware allowing, and ip addressing correct, it sounds like the next step should be focused towards circuit mapping. Good luck.
it is a direct fiber cable between the two routers with 2 Km distance
Both interfaces are up, line protocol are up
but CRC error , and no input packets, and I can'r ping both ends
thanks
Magdy
http://www.cisco.com/warp/public/121/crc_tshooting.html
This link will provide you with info on determining why you are seeing CRC errors on your ATM interfaces. Hope it helps.
184
