autoinstall over frame-relay interface
Should i use "ip direct broadcast" when a new router is
connected by a Frame-relay interface?
1 REPLY
Bronze
Re: autoinstall over frame-relay interface
That command is not necessary. If you are not using sub-interfaces, use the following commands:
interface serial x
ip address a.a.a.a
ip helper-address (address of TFTP server)
frame relay map ip (ip address you wish to assign to the new router) (lci #)
If you are using sub-interfaces, use the following:
interface serial x.y
ip address a.a.a.a
frame-relay interface-dci protocol ip (ip address you wish to assign to the new router)
Good luck.
Mark
88
