Aux to Console Connection
I recently heard through a friend that there is a way to connect your routers aux port to a switch's con port as a back door of sorts if you can't connect to the switch through telnet and you are not on site. Can anyone tell me how to setup my router and switch to do so? Thanks
Silver
Re: Aux to Console Connection
router config
line aux 0
transport input all
no exec
session-timeout 15
exec-timeout 15 0
switch config
line con 0
exec-timeout 15 0
to connect from the router out the aux port
do a sh line this will show you the aux line # then reverse telnet to this line .
on a 2600
router# sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - - - - - 0 0 0/0 -
129 AUX 9600/9600 - - - - - 0 0 0/0 -
router# telnet 10.0.0.1 2129
you must use an ip address on the box that is up up best one to use is the loopback.
What does the "CTY" mean?
Silver
that is the console line
great! it worked..thanks for the help :o)
612
