BackHaul Connectivity Problem
I have a bit of a problem with my setup.
Refer to the configs below.
The routers a connected on a backhaul for my VSAT Network and router 2's ethernet connects into the DPC(Data Port Card) at the VSAT HUB/EarthSatation on Ip Address
190.0.1.187/24 and its ethernet0 is 190.0.1.186/24
When I am sitting in the router 1 at Head Office, I can successfully ping all the sites on my network (all entries in /etc/routes file)
but when sit in the Server (ip 190.0.0.199/24) I can only ping as far as the ethernet of router2 (190.0.1.186/24)at Earth Station/HUB. I cant even ping the DPC (190.0.1.187/24) in the same subnet!!
I feel the problem is with the Server but I cant figure out where!
Router 2 @ VSAT Hub or Earth Station
show run
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname GMBMAZOWEBACKHAUL
enable password 7 1515060E
ip subnet-zero
interface Ethernet0
ip address 190.0.1.186 255.255.255.0
no ip directed-broadcast
interface Ethernet1
no ip address
shutdown
interface Serial0
ip address 190.0.10.186 255.255.255.0
encapsulation ppp
ip classless
ip route 0.0.0.0 0.0.0.0 190.0.1.187
no ip http server
line con 0
password 7 110E1407
login
transport input none
line 1
line vty 0 4
password 7 045C0604
login
end
GMBMAZOWEBACKHAUL#exit
[Connection to 190.0.10.186 closed by foreign host]
Router 1 @ Head Office
GMBHARARE#show run
version 11.2
no service udp-small-servers
no service tcp-small-servers
hostname GMBHARARE
ip subnet-zero
interface Ethernet0
description Link to GMB Head Office
ip address 190.0.0.187 255.255.255.0
no logging event subif-link-status
interface Ethernet1
no ip address
shutdown
interface Serial0
description link to Harare GMB
ip address 190.0.10.187 255.255.255.0
encapsulation ppp
ip classless
ip route 0.0.0.0 0.0.0.0 190.0.10.186
line con 0
password 7 1049041B
login
line vty 0 4
password 7 07082C4E
login
end
Server Address 190.0.0.199 255.255.255.0
Server Routing Routing table in /etc/routes
net 200.15.15.0 190.0.0.230
-net 200.15.15.0 190.0.0.230
-net 15.0.0.0 190.0.0.230
-net 190.0.9.0 190.0.0.230
-net 190.0.2.0 190.0.0.187
-net 190.0.3.0 190.0.0.187
-net 190.0.4.0 190.0.0.187
-net 190.0.5.0 190.0.0.99
-net 190.0.6.0 190.0.0.187
-net 190.0.7.0 190.0.0.187
-net 190.0.8.0 190.0.0.187
-net 190.0.0.0 190.0.0.187
-net 190.0.10.0 190.0.0.187
Bronze
Re: BackHaul Connectivity Problem
Check the configuration of the DPC. Make sure that it has a default gateway of 190.0.1.186, or a route that points the server's network to that address.
Good luck.
Mark
Thanks for your advice but it didnt work, it had to work in some other way!!
I had to restart the server (Digital Unix) with the new routing table and it worked!!
Tongesai
Silver
Are the E0's of R1 & R2 supposed to be on the network 190.0.0.0/24 ?
If they are the e0 of router 2 has an ip address on a different subnet 190.0.1.0/24
I had to restart the server for the new routing table to take effect and it worked.
Tongesai
84
