You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Backplane speed V/s Number of Ports supported on catalyst 4006.
Understand that catalyst 4006 switch has 64 Gbps backplane speed.
Also understand from the maximum port density table of catalyst 4006 as
10/100 - 240 ports, 100 Base FX - 240 ports.
Also understand that this switch supports 10/100/1000 - 240 ports.
How do we justify the back plane speed(64 Gbps) with 240 * 1000 Mbps ports on a single catalyst 4006 switch.
What is the relationship between the Backplane speed and the number of available ports?
regards,
n.s.ravishankar
  • Other Network Infrastructure Subjects
Re: Backplane speed V/s Number of Ports supported on catalyst 40
The uplinks are non-blocking. Each line module has 12 GBbps (6 each way) for switch fabric connections.
Understand this, Can we have more detailed information on catalyst 4006 architecture.
n.s.ravishankar
262
