backup interface nat translation automation
i am having a 2651..
original setup was using 2 ethernet with nat overload on the f0/1..now we installed addtional isdn interface for backup purposes..the shifting between interfaces (f0/1 and bri0/0) was okay but the nat seems giving me a problem..ive iolated the problem by doing the following;
1 disable the original nat overload
2 invoking the bri0/0 overload
after this process, only it will work.
what i wanted is fully automated...such that when the bri becomes active, it shoud use the bri0 overload, and when it gets bak to f0/1, it should be able to go back to its original nat overload.
ty
  • Other Network Infrastructure Subjects
Bronze
Re: backup interface nat translation automation
You can configure your NAT to match the ip address and outgoing interface to make this work:
For example:
ip nat inside source route-map ethernet interface f0/1 overload
ip nat inside source route-map isdn interface bri0/0 overload
route-map ethernet
match ip address 1
match interface f0/1
route-map isdn
match ip address 1
match interface bri0/0
access-list 1 permit 10.0.0.0 0.0.0.255
hi,
thanks a lot..i really appreciate it...it works..
again, my many thanks.
115
