Balanced and unbalanced with a NM-2CE1B
Hello!
Could anyone explain why a NM-2CE1B shows up as "unbalanced"? (see the output of commands sh contr e1 and sh diag below). According to the specs this is a balanced card.
Router#sh controllers E1
E1 1/0 is down.
Applique type is Channelized E1 - unbalanced
Transmitter is sending remote alarm.
Receiver has loss of signal.
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (430 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 430 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 430 Unavail Secs
Total Data (last 1 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
1 Slip Secs, 900 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
E1 1/1 is down.
Data in current interval (440 seconds elapsed):
0 Slip Secs, 440 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 440 Unavail Secs
Router#sh diag
Slot 0:
C2612 1E1R Mainboard port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.1 Board revision A0
Serial number 692912706 Part number 73-2841-06
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 93 01 01 29 4D 02 42 49 0B 19 06 00 00 00 00
0x30: 50 00 00 06 00 00 00 00 00 00 00 00 00 00 00 00
Slot 1:
CE1 (Unbalanced) port adapter, 2 ports
Hardware revision 1.1 Board revision C0
Serial number 28612578 Part number 800-02117-04
0x20: 01 3B 01 01 01 B4 97 E2 50 08 45 04 00 00 00 00
0x30: 60 00 00 00 01 09 10 00 FF FF FF FF FF FF FF FF
Thank you,
Barry
Re: Balanced and unbalanced with a NM-2CE1B
I guess this is correct and this does not have any effect on network health.
Barry,
This module has a jumper setting which can be set to 120 Ohm balanced or 75 Ohm Unbalanced.
Seems that the jumper is on Pins 1 and 2 which equates to unbalanced you will need to move them to 2 and 3
Hope this helps
Adios
Dale
This refers to the physical cable type you need to use with it i.e. Balanced = 120 ohm CAT5 UnBalanced = 75 Ohm Coaxial
130
