Balanced Network Module vs Unbalanced Network Module
Please what is the difference between a 3600 series cisco 1-port channelized E1/ISDN-PRI Balanced Network Module and a 3600 series cisco 1-port channelized E1/ISDN-PRI Unbalanced Network Module?
Silver
Re: Balanced Network Module vs Unbalanced Network Module
Wheather you run in balanced or unbalanced will depend on the carrier . Make sure you get from the carrier if they are going to be running balanced or unbalanced, then your card must match .
The balanced is available in 120 ohm and unbalanced in 75 ohm ( different physical hardware)
134
