Community Member
Bandwidth Command on Serial Interface
Hi all,
The router at my cleint location using EIGRP routing protocol is having T1 link, but bandwidth(S0) is configured as 1544000. They will be getting soon T3 between the same locations and may want to use the existing T1 link as Backup and with HSRP between both the outers(T3&T1- with T3 router High priority). Now what is going to happen to EIGRP with the bandwidth command in place?
Thanks a mil.
Mehboob
Gold
Re: Bandwidth Command on Serial Interface
EIGRP is going to use the link with the highest bandwidth/lowest delay, as configured at the interface level. It sounds like the bandwidth may be set right, just possibly too many 0's (are you taking the configured bandwidth from the show interface, or the show run?).
I would configure the bandwidths to what they really are, and then adjust the delay as necessary over the backup link to get the routing you want. Remember the metric is applied inbound with EIGRP, not outbound, so the transmitting router sends an update just as it has it in its local table, the receiving router takes the bandwidth and delay listed in the update and adjusts the metrics based on the interface the update was received on.
Russ.W
Community Member
Thanks Russ.The Bandwidth is from SH RUN.
Gold
I just checked, and it's the delay I'm thinking of that has a one 0 difference between show run and the show output. For instance, on a 2600, I have this:
interface Serial0/1
bandwidth 100
ip address 208.0.16.10 255.255.255.0
encapsulation frame-relay
delay 100
clockrate 1000000
frame-relay interface-dlci 36
And the show output shows this:
2651A#show ip eigrp topo 208.0.16.0
IP-EIGRP (AS 100): Topology entry for 208.0.16.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 25625600
Routing Descriptor Blocks:
0.0.0.0 (Serial0/1), from Connected, Send flag is 0x0
Composite metric is (25625600/0), Route is Internal
Vector metric:
Minimum bandwidth is 100 Kbit
Total delay is 1000 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1500
Hop count is 0
Note that delay shows as 100 in the show run, and 1000 in the show ip eigrp topology....
Anyway, I hope that setting the bandwidth and delay gets your load sharing where you want it to be. Note that I would normally recommend not setting your bandwidth to engineer traffic flows, because EIGRP paces packets based on the configured bandwidth. I don't think it's going to make much difference in this case, however--it's generally more problematic when you have thousands of routes over low speed links (T1 and below) on large hub and spoke implenations.
Russ
Community Member
Thanks again Russ..
But If I do not have Delay configured on the interface, then with the existing Scenario(T3 coming in pic.) whats going to be the result?
interface Serial3
description "link to Branch#1"
bandwidth 1544000
ip address < > < >
no ip directed-broadcast
ipx network B3E4
Gold
You would need to know the bandwidth and the delay on both interfaces from a show interface to know. BTW, that bandwidth should still have the two 0's knocked off--bandwidth is entered in k-bits/sec, rather than bits/second, so if this is a T1, it shoudl be 1544. In fact, for a serial link, T1 is default, so if it's a T1, you shouldn't have to enter a bandwidth command.
What's the bandwidth set to on the T3 side? Can you post a show interface with the bandwidth and delays for the two interfaces?
Russ.W
Community Member
Serial2 is up, line protocol is up
Hardware is HD64570
Description: "Branch"
Internet address is < >
MTU 1500 bytes, BW 1544000 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
Last input 00:00:01, output 00:00:02, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/3/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
--- T3 is not yet UP, but the BW configured on T3 interface is 44000.
THX
Gold
I would either set the bandwidth on the T1 for 4400, or set the bandwithd on both of the links to 1544. The delay should take care of itself once this is done.
Russ.W
Community Member
Thanks alot Russ. I consider changing the BW back top 1544 on Serial interface.
Also, How can I remove the previous questions posted in NetPro..?
Thanks a mil
MS
Gold
Okay--that should do the trick.... I don't know how to remove questions from netpro--it's something I've asked before, and I think the answer is generally that you can't.
Russ.W
1502
