Bandwidth issue
Hi All,
I have 2950 switch, multiple vlans created on it, Is there any way to configure specific vlan with particular bandwidth speed?
Also, if I configured specific port as follows:
(conf)int f0/2
bandwidth 2048000
Does the above means 2mb speed up/down?
thanks,
1 REPLY
Purple
Re: Bandwidth issue
I'm afraid that will not achieve what you want. There is no way to limit all traffic to a specific bandwidth for a VLAN on the 2950.
I would suggest that you apply a QoS service policy on the router that does inter-vlan routing for this VLAN in order to achieve your rate-limiting.
Pls do remember to rate posts.
Paresh
102
