bandwidth management
I want to know bandwidth magement on cisco router i am having 512kb link from isp that i need to split into 2 links on 2 diffrent network. how i can do?
----512kb-----S0 Router-----e0 192.168.20.x/32
e1
192.168.29.x/32
i want e0 to have 128kb and 384kb e1 (ethernet1 interface)
want to have details of commands to be used if it is possible in ios.
VIP Purple
Re: bandwidth management
you could use classes to define traffic and then assign bandwidth, it would look like this:
class-map match-all Ethernet0
match access-group 1
class-map match-all Ethernet1
match access-group 2
policy-map ISPEthernet0
class Ethernet0
bandwidth 128
policy-map ISPEthernet1
class Ethernet1
bandwidth 384
interface Ethernet0
service-policy output ISPEthernet0
interface Ethernet1
service-policy output ISPEthernet1
access-list 1 permit 192.168.20.0 255.255.255.0
access-list 2 permit 192.168.29.0 255.255.255.0
Georg Pauwen
Is there any more solution to this scenrio?
Is there any more solution to this problem? whis is best?
is there any more soulution? which is best?
VIP Purple
you could try the rate-limit command in interface config mode. Just make sure that it doesn´t affect traffic between the hosts connected to both interfaces on your router (e.g. the rate-limit command lets you specify an access list which the traffic to be rate-limited has to match).
Georg Pauwen
87
