bandwidth mismatch in Point-to-Point link
In point-to-point serial link connection, if the bandwidth setting on both sides are not the same, will the connection status is up and running? What will the bandwidth be? The lower one?
1 REPLY
Purple
Re: bandwidth mismatch in Point-to-Point link
As I indicated earlier, the bandwidth configured at the interface level is only used for IGP metrics etc. If set to be different at either end, it will not affect the physical state of the interface. It will stay up.
However, it's better to make them the same.
PAresh
232
