Bandwidth statement for FR-ATM
When working with a full T-1, I am just wondering what is the difference between a bandwidth statement of 1544 and 1536. I understand that 1536 comes from 24 channels of 64k, but I don't understand where the 1544 statement comes in hand. Here is the setup where I'm not sure which statement to put in,
ATM statement:
7204VXR router
interface ATM1/0
atm pvc aa bb cc aal5snap 1536or1544 1536or1544 xx inarp yy
FR statement:
2620 router
interface serial 1/0
bandwidth 1536or1544
Thank you!
Re: Bandwidth statement for FR-ATM
1544 is the theorheitcal bandwidth of a T1. As you stated, the 1536 rating is achieved via 24 channels, or DS0's, that increment @ 64 kbps each. I have seen many configs using both 1536 and 1544 as the bandwidth statements, and I haven't seen any complications with either setting used. To be technically correct, use 1536.
Good luck.
The way you get 1544 is
24 channels x 8 bits = 192 bits
Framing bit 1 bit
Total 193 bits
Frames per second x8000
Rate for T1 = 1544000bps
But if you take out the framing bit, 1536000bps.
So effective rate you get is 1536000bps.
Shajith
141
