Bandwith display errors using CMS on a 3524 switch
When i graphicaly display bandwidt using the CMS (revision augus 2002) on a 3524 switch, there seems to be a mis match between displaying the rate in Kbytes en % load.
There is also a substatial mismatch in wat is the real bandwith.
I tested i on a 2 Mbit internet feed (non overbooked) By DOWNLOADING A FILE the microsoft download progress displayed a rate of 1.8 Mbit, while the link graph on the same port displayded 4.000,000 Kbytes, that is 3,2Mbit.
Is this a well known problem.
Rolf
1 REPLY
Re: Bandwith display errors using CMS on a 3524 switch
If the link graph is showing 3.2 MB on a 2MB link, I would suspect a software issue. You may need to open a case with Cisco on this, or try the Bug Toolkit here: http://www.cisco.com/cgi-bin/Support/Bugtool/launch_bugtool.pl
106
